default behavior
SpencerC
default behavior
Post by SpencerC »
Hello All!
I'm curious if there is a way to modify the default behavior. After inserting a bluray disk and after it does it's scan of the disk, it generates a list of potential files to convert to mkv files. I then have to go in and uncheck almost all of them and just keep the large file sizes. Some of these disks can generate a rather long list of not needed files. I've got one disk right now that generated probably over 100 that I need to go and uncheck all of them and just select the 1 file I want. Is there a way to default it to NOT check any of these boxes so I can then just check the 1-3 boxes I actually want?
thanks!
Spencer
Re: default behavior
Have you tried RIGHT clicking on the list, and selecting "Unselect all" yet?
SpencerC
Post by SpencerC »
Woodstock wrote: Tue Jul 07, 2026 1:12 pm Have you tried RIGHT clicking on the list, and selecting "Unselect all" yet?
oh boy..........sigh. LOL! I suck. Thanks!
