black_raven wrote: Fri Jul 03, 2026 9:13 pm Hi, have my ASUS BW-16D1HT with the following firmware for many years.
Looking for advice whether there is some newer version worth flashing?
Use the drive mostly for ripping my CD and BD/UHD collection...thanks
OS device name: W:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: KEJIXXXXXXX
Firmware date: 2117-11-24 14:13
Bus encryption flags: 1F
Highest AACS version: 61
Firmware version: 3.02
Leave it alone unless you are having UHD read issues. Not worth flashing it otherwise as you don't gain anything.
black_raven
Post by black_raven »
Thank you for the advice, will leave it alone then 8)
The only small issue I experience is that "Exact Audio Copy" (EAC) is reporting the drive is unable to successfully detect C2 Errors during audio CD ripping. But nothing indicates that the newer firmware 3.10MK improves this.
AM6B+ Coreelec, OPPO UDP-203, Asus PC BW-16D1HT
ZedHead23
Post by ZedHead23 »
Hey Billy quick question, I bought a BP50NB40 NB52 drive, it reads normal blu rays fine, and if I messed up the drive that's my mistake, but I flashed it to libre drive 2 months ago, and I didn't cross flash it, after the first flash, so it says "Libredrive enabled" and all that, but I never cross flashed it to the BP60NB10 or whatever. I also have the original backup still from the first time I flashed it, but I'm just curious if I can fix it, cause I tried flashing it again and it won't flash at all, even though SDF Tool says it flashed. Again it reads normal blu rays fine, but when I do UHD Blu rays it doesn't work in MakeMKV.
ZedHead23 wrote: Mon Jul 06, 2026 1:01 am Hey Billy quick question, I bought a BP50NB40 NB52 drive, it reads normal blu rays fine, and if I messed up the drive that's my mistake, but I flashed it to libre drive 2 months ago, and I didn't cross flash it, after the first flash, so it says "Libredrive enabled" and all that, but I never cross flashed it to the BP60NB10 or whatever. I also have the original backup still from the first time I flashed it, but I'm just curious if I can fix it, cause I tried flashing it again and it won't flash at all, even though SDF Tool says it flashed. Again it reads normal blu rays fine, but when I do UHD Blu rays it doesn't work in MakeMKV.
as guide says you need to crossflash to do UHD
email me or marty for an auto flasher
or see guide here
tcharp
Post by tcharp »
I have never felt like so much of a dumbass as when I try to read this thread.
Can someone, perhaps, tell me what I need to do, or what to flash, in order to read 4K UHD media?
And then attach a screenie of a Home Depot receipt instead of what y'all needed. I guess I am a dumbass.
tcharp
Post by tcharp »
I guess I am not attaching any photos at all. Let me try again.
A common problem is that the board does not accept links from social media sites as "pictures". If you link to the .JPG, .GIF, or .PNG image itself, you see the picture; if you link to the page given by the site that includes the link to the picture, you do not get anything. And a lot of such sites "protect" your images by hiding them immediately after you post them. Some even make the links disappear after a set length of time (this is a big issue with Facebook, amongst popular sites).
Attaching photos is not really necessary, though. MakeMKV screens include copyable text that contains drive information.
tcharp
Post by tcharp »
Thanks for the reply. The photo I am trying to attach is just a screenie of the MakeMKV window that is sitting on my desktop.
C:\Users\Terry\Desktop\New Picture (2).png
Not sure why I still am not seeing that .png file. Anyway, this is the text from the window. That I am not really even sure how to read, or what most of it means.
OS device name: I:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIM21L8L94638
Firmware date: 2121-07-08 16:03
Harware support: Yes
Firmware support: No
Firmware version: 1.03
tcharp wrote: Mon Jul 06, 2026 9:22 pm Thanks for the reply. The photo I am trying to attach is just a screenie of the MakeMKV window that is sitting on my desktop.
OS device name: I:
Revision: 1.03
makemkvcon64.exe f --all-yes -d "your drive letter here Example" D: rawflash enc -i "path to your firmware Example": C:\Users\BP50NB40-NB50-1.03MK.bin
makemkvcon64.exe f --all-yes -d "your drive letter here Example" D: rawflash "main,nowait,nocheck,boot=MT1959 Boot BUP3" -i "path to your firmware Example": C:\Users\DE_LG_BU40N_1.00.bin
Or email me or Marty for an automated flasher see below for email
