Do I need to flash my BDR-XD05
Re: Do I need to flash my BDR-XD05
NCiH85 wrote: Thu Jun 04, 2026 10:10 am
I am unable to PM you. Can you help me out? Thanks
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
RandomStatic
Post by RandomStatic »
Coopervid wrote: Wed Jun 11, 2025 7:28 pm
buyitownit wrote: Wed Jun 11, 2025 6:02 pm Yes, having UHD capability would be ace!
PM sent.
Hi there - same boat for me. New user, cannot PM. Drive details below. Mind helping me out, please? Thank you.
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 1.21
Serial number:
Firmware date: 2014-04-02
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 1.21
RandomStatic wrote: Mon Jul 06, 2026 4:57 pm
PM sent.
Revision: 1.21
Serial number:
PM sent.
RandomStatic
Worked perfectly - Cheers!
rachaj
Post by rachaj »
Hello, Would you be able to assist with this information? Thanks in advance!
Product: BD-RW BDR-209M
Revision: 1.20
Serial number: NLDL040277WL
Firmware date: 2014-04-08
Highest AACS version: 82
Drive platform: RS8600
Firmware version: 1.20
rachaj wrote: Tue Jul 07, 2026 10:33 pm Hello, Would you be able to assist with this information? Thanks in advance!
Revision: 1.20
see below for email
bradneat
Post by bradneat »
I also have a BDR-XD05 that I want to use to rip 4K UHD discs. My drive info is:
OS device name: E:
Revision: 3.10
Serial number: SEDL025598WL
Firmware date: 2017-06-22
Highest AACS version: 19
Drive platform: RS8232
Firmware version: 3.10/ID34
Can I flash the firmware to be able to do this?
bradneat wrote: Wed Jul 08, 2026 5:57 am I also have a BDR-XD05 that I want to use to rip 4K UHD discs. My drive info is:
OS device name: E:
Revision: 3.10
PM sent.
OS device name: E:
Revision: 3.10
see below for email
Revision: 1.20
PM sent.
rachaj
Post by rachaj »
Coopervid wrote: Wed Jul 08, 2026 10:07 pm
Revision: 1.20
PM sent.
Thanks so much!
spazalot
Post by spazalot »
Just started to use MakeMKV after getting a bucket load of DVD, Bluray and UHDs. I was looking at getting my drives setup to dual load discs. The BDR-XD05 has a newer firmware which seems to be a issue related to being newer. My BDR-X13 drive seems to be "Possible" but not enabled. Is this drive in a state where I can't get LibreDrive installed and UHD also?
OS device name: \Device\CdRom2
Revision: 1.22
Serial number: <Removed>
Firmware date: 2023-03-02
Highest AACS version: 63
Drive platform: Pioneer RS8231
Firmware version: GENE
spazalot wrote: Sat Jul 25, 2026 5:16 pm Just started to use MakeMKV after getting a bucket load of DVD, Bluray and UHDs. I was looking at getting my drives setup to dual load discs. The BDR-XD05 has a newer firmware which seems to be a issue related to being newer. My BDR-X13 drive seems to be "Possible" but not enabled. Is this drive in a state where I can't get LibreDrive installed and UHD also?
Revision: 1.22
see below for email
