I have tried that... What bugs me is that the disc as clean as I can get and BOTH drives are having the problem.... Driving me nuts!MartyMcNuts wrote: Sun Jul 27, 2025 5:30 amThose mean the drive is having trouble reading a section of the disc. Try cleaning the disc before attempting to rip it again.rlentz2024 wrote: Sun Jul 27, 2025 1:33 am I'm sorry guys... I'm at a lost... I have two different drives and they both give the following errors with Avatar, The Way of the Water.
-Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR'
-STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0'
- MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '
I swore I ripped it in early 2025 on a different version and now on 1.18.1 But now that I'm trying to rip it again (To have a Remux copy), I get the above errors and don't know why.
Also have done the lastst Find VUK as of today with no luck. Any help would be great.
If you're experiencing rip errors, please read here first!
rlentz2024
Re: If you're experiencing rip errors, please read here first!
Bombart
Today i got a UHD disc that shows me many of these m2ts errors and cant be ripped.
The first information you get here is to clean your disc.
Ok sometimes there are fingerprints or dust on a disc but sometimes the disc is clean and you got also these errors.
First i thought that the disc was defect.
I testet it in my StandAlone Player...it works.
Ok, ripping with makemkv an wantching in a Player is not the same, so i take the disc put it in the same drive and tested it with VSO Inspector. VSO Inspector cant find any errors.
After that i searched the net, every time you can read that the disc is defect or must be cleaned.
After that i put the IO settings to a higher level than 5 after that i added this to the mkv registry (you find it under KEY_CURRENT_USER):
io_IgnoreReadErrors
you must create it with DWORD and activate it with 1
After that i try the same disc again and got the same m2ts errors but now the disc can be ripped succefully.
I tested the mkv on my vlc and the movie plays without any errors.
So whats going on here? When so many m2ts files are really corrupt because of dust or a disc defect it is absolutly not possible that the ripped mkv file worked without any issues.
io_IgnoreReadErrors
MBarb64
Has anyone had this issue with Back To The Future?
It's not so much dust or a defect (yes, there are quite a few defective UHD discs about). It is more the fact that most UHD discs have an invisible layer of film on them from the manufacturing process that needs to be cleaned off.Bombart wrote: Fri Nov 21, 2025 12:14 am Today i got a UHD disc that shows me many of these m2ts errors and cant be ripped.
io_IgnoreReadErrors
sbader724
I was searching for this. I just got the box set and the first 2 discs ripped fine but the 3rd failed multiple times. First time I've had an issue with a brand new disc but I'll try cleaning again.
Ichirare
Hello. I'm new here. How do you safely clean it off? I have a Hobbit UHD release that I can't rip. It either doesn't load correctly or when it does, the drive freezes.MartyMcNuts wrote: Thu Dec 11, 2025 10:42 pm It's not so much dust or a defect (yes, there are quite a few defective UHD discs about). It is more the fact that most UHD discs have an invisible layer of film on them from the manufacturing process that needs to be cleaned off.
Try giving it a good wipe with a microfiber cloth first and see if that helps. If not, try a deeper clean using a microfiber cloth and soapy water then dry with a microfiber cloth and let it finish air drying overnight.Ichirare wrote: Mon Feb 23, 2026 8:35 pmHello. I'm new here. How do you safely clean it off? I have a Hobbit UHD release that I can't rip. It either doesn't load correctly or when it does, the drive freezes.MartyMcNuts wrote: Thu Dec 11, 2025 10:42 pm It's not so much dust or a defect (yes, there are quite a few defective UHD discs about). It is more the fact that most UHD discs have an invisible layer of film on them from the manufacturing process that needs to be cleaned off.
If it still doesn't work after that, try a different drive as not every drive will read every disc. If still not working in anther drive, the disc is probably faulty.
ChildishhAlbino
Hi all!
Hoping you can help me with an error I'm having with a specific disk (at this time, it doesn't seem to be affecting any other disks).
tl;dr
- Purchased Attack on Titan Season 3 Steelbook. Part 2, Disc 2 of that season just will not read/rip in my LG BD-RE WH16NS60 (Flashed to read UHD discs)
- It does read in my PS5 and in my dad's LG drive (not flashed)
The disc just seems to cause my drive to spit out garbage because I get errors like
and
If the disc DOES show up properly in MakeMKV - it doesn't read properly (the logs in my MakeMKV container say "Disk is not a BD/DVD")
Any advice is appreciated - I'm hoping the drive just needs a clean or something? Just doesn't make sense to me why ONLY this disc fails in ONLY this drive.
Could reflashing the firmware help? Or is that only likely to cause more issues.
tl;dr
and
adamnz
Thanks for this comprehensive list! It's a great baseline for troubleshooting. Unfortunately, I'm still running into the Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR even after trying all the suggested steps. I've gently cleaned the disc with a microfiber cloth, increased the read retry count, and even swapped from my external USB drive to an internal SATA one, but it still fails at the exact same spot. Has anyone found that certain studio batches are just completely unreadable out of the box? Looks like I might just have to return this disc and hope the replacement comes from a better batch
ember1205
Seems there's a manufacturing error in the disc itself. You can play it on a player, but you're likely never going to rip it with an error like that.adamnz wrote: Thu Mar 12, 2026 6:00 am Thanks for this comprehensive list! It's a great baseline for troubleshooting. Unfortunately, I'm still running into the Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR even after trying all the suggested steps. I've gently cleaned the disc with a microfiber cloth, increased the read retry count, and even swapped from my external USB drive to an internal SATA one, but it still fails at the exact same spot. Has anyone found that certain studio batches are just completely unreadable out of the box? Looks like I might just have to return this disc and hope the replacement comes from a better batch
stephen273
I got an error: Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR with a link that sent me to this:
"The simple workaround is to copy all files from the disc to the hard drive manually, without MakeMKV running. If you succeed in this, there is a fast and simple way to convert such copy into encrypted MakeMKV backup that can be opened by MakeMKV later. See our forum for details."
So I succeeded in copying the files manually, what is the "fast and simple" way?
Barrus
I also got to that error page after trying to rip a movie. I am also wondering where I can find info about that "fast and simple" way.stephen273 wrote: Sun Mar 22, 2026 2:30 am Hello,
It would be good if there was a link to that manual/forum topic, instead of just refer to "forums" in the error message...
Can anyone help, please? This was certainly not a fast and simple way of doing it...
Sorry if I sound bitter, but it really bugs me when someone says "it's so easy, but I am not gonna tell you how!"
spotdog19
July 2026....And THIS method worked perfectly for my DVD's. I was trying to rip Season 8 (3 disc set) of the TV series Psych...all 3 discs came back with errors, the other 25+ discs in the series worked perfectly. The download makes an ISO file. You then go to "File" in the makemkv program, open the location that the ISO file is saved in and operate the program like normal. Took only 3-4 minutes to rip the whole disc from there. PERFECT.
nitsuJcixelsyD wrote: Fri Nov 15, 2024 1:35 amBlast from the past but I just wanted to thank you for this method. This worked for me for 3 disks that would error out on directly making the MKV file.Nontheistzero wrote: Sat Dec 19, 2020 11:51 pm Here's what I did to rip a disk that was reporting the error - Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR.
Step 1: Use makeMKV's backup tool to dump the disk
Step 2: Use the backup to extract the movie by clicking open file, go to the backup folder you just created, go under the BDMV folder, and select the index.bdmv file.
Step 3: Extract with whatever options you like as per usual
I don't see this method listed as things you should try and I don't really understand why it works in this case. Everything I read suggests my disk is bad. I've read multiple people have returned their disks, only to receive another disk that does much the same thing. I've cleaned this particular disk and it's perfectly fine with no scratches, marks, blemishes etc. It was fresh from a new purchase. I literally had it report a failure to read the disk and immediately launched into the backup tool to make the rip and the rip reported no errors. Perhaps there is a difference in the mode that is used to read the disk for backup? I don't know.
Perhaps someone that is much more experienced could explain why it would fail on a normal rip but still be able to create a working backup.
ScotSabr772982
I'm new to MakeMKV and this is the first time I've seen this. I have been fairly successful ripping my library (over 1400 DVDs, Blu-Rays, and UHDs). I am about 975 movie and TV shows into the process. I have 3 drives set up for faster throughput. But today I saw an unusual error, one which hasn't showed up in the this thread:
Error 'OS error - The system cannot find the path specified' occurred while creating 'C:/Video/Say Anything.../Say Anything..._t10.mkv' (direct copy and paster from MakeMKV window).
The above error shows up just after it creates the file folder for the movie.
I have seen several of the other errors mentioned in the thread and a thorough cleaning has usually fixed the problem, or using one of the other two drives, and as a last resort using a new disc (on 4 titles).
This one stumped me. Has anyone else seen this error before.
I also tried this on a second drive and I get the same error.
BTW, I had just booted my ripping PC up for the day so the system was fresh.
Last edited by ScotSabr772982 on Mon Jul 06, 2026 12:24 am, edited 1 time in total.
Sayaka
Please do not end a folder name (or file name) with a dot. Windows does not support this.Error 'OS error - The system cannot find the path specified' occurred while creating 'C:/Video/Say Anything.../Say Anything..._t10.mkv' (direct copy and paster from MakeMKV window).
If you change the folder name to "Say Anything" rather than "Say Anything...", I believe it should work, and you might want to remove the dots from the file names as well for good measure (except for the file extension - ".mkv").
