ASUS BW-16D1HT - MFG Dec 2024 but firmware 3.02? Could this be a fake / shell-swap / patched? (New User)
BreezyCarp
#1 Post by BreezyCarp » Fri Jul 03, 2026 9:11 am
Hi everyone,
Recently I got myself an ASUS BW-16D1HT drive, and I found something strange. The drive looks pretty new, but for some reason it's on firmware 3.02 dated November 24, 2017. So I'm a bit worried there might be something fishy going on with this unit. If this is genuine, does it mean nothing needs to be done? I would really appreciate it if you could help me out.
Here's some info (see attached pictures for more details):
OS device name: E:
Manufacturer: ASUS
Revision:3.02
Product: BW-16D1HT
Serial number:KLF0CBE2320
Firmware date:2117-11-24 14:13
Bus encryption flags: 1F
Firmware type: Original(unpatched)
Firmware version:3.02
tomty89
Re: ASUS BW-16D1HT - MFG Dec 2024 but firmware 3.02? Could this be a fake / shell-swap / patched? (New User)
#2 Post by tomty89 » Fri Jul 03, 2026 12:41 pm
Was it sold as unused / brand new? If not then it's not exactly surprising that it was flashed with DE firmware or maybe even OmniDrive.
something fishy
Well better test it with at least one UHD BD before you can't return it. Not exactly sure if you can tell it is really MT1959 with just the LibreDrive information.
RibShark
#3 Post by RibShark » Fri Jul 03, 2026 10:17 pm
There are a lot of counterfeit drives from China at the moment that are probably pieced together with spare parts. Tells are:
  • Incorrect or inconsistent fonts on the labels.
  • For desktop drives, biggest tell is if the circular sticker at the top has an large indent directly around it (fake for MT1959 drives) rather than instead having four small dimples some distance away from the sticker (real). Note that some real, non-MT1959 drives, have the large indent too.
  • For desktop drives, the rectangular sticker having "INTERFACE CONNECOTOR" (fake) at the bottom instead of "INTERFACE CONNECTOR" (real).
  • For desktop drives, the rectangular sticker having "DVD FORMAT|LOGO" (fake) rather than "DVD FORMAT/LOGO" (real).
  • For desktop drives, having no black stamped serial on the back panel (can be hard to see since it's black on black), real drives have serial stamped in black ink.
  • For ASUS drives, the drive having a manufacturing date above 2020 but the address listed as "Li-Te Rd.,Peitou,Taipei" (fake if >2020); real drives made later than then have the address listed as "Lide Rd.,Beitou,Dist.," instead (real).
  • For the BU40N/BU50N, the KCC ID being listed as "KCC-REM-LGE-BU40N" rather than "KCC-REM-HLD-BU40N".
  • For the BU40N, there should be a 1/3 of a circle indent around the bottom left of the sticker (real); if this is absent the drive is fake. The BU50N and other slim drives may lack this indent even on real drives however.
  • For slim USB drives, the LG logo on the top of the casing being misaligned to the text next to it.
Not all fakes will have all of these problems, but I've not seen a fake that doesn't have at least one of them. If you are still unsure a picture of your drive will likely clear up whether it is legitimate or not.
OneDay
#4 Post by OneDay » Sat Jul 04, 2026 12:49 am
Here are example of real and fake and if it is legit MT1959
If you don't see this is on the back by the power sata ports its not a MT1959 UHD friendly drive - Next is the legit drive - Next is the Chinese knock off
https://drive.google.com/file/d/1QPu43o ... sp=sharing
https://drive.google.com/file/d/1oJMRec ... sp=sharing
https://drive.google.com/file/d/1HNw0jj ... sp=sharing
BreezyCarp
#5 Post by BreezyCarp » Sat Jul 04, 2026 4:34 am
RibShark wrote: Fri Jul 03, 2026 10:17 pm There are a lot of counterfeit drives from China at the moment that are probably pieced together with spare parts. Tells are:
Detailed photos are available here:
https://i.imgur.com/vi3Gq3t.jpeg
https://i.imgur.com/FSjmxMl.jpeg
https://i.imgur.com/xQZeUCH.jpeg
https://i.imgur.com/ON2adwo.jpeg
https://i.imgur.com/IROOI5z.jpeg
https://i.imgur.com/Afgevua.jpeg
https://i.imgur.com/GD3sOeM.jpeg
https://i.imgur.com/4mX2DLE.jpeg
https://i.imgur.com/5zDZgAW.jpeg
https://i.imgur.com/UUX0avx.jpeg
https://i.imgur.com/bakZEvP.jpeg
https://i.imgur.com/kUnv2Gs.jpeg
https://i.imgur.com/j7BDEY0.jpeg
https://i.imgur.com/EU4WY8C.jpeg
https://i.imgur.com/npDH3oU.jpeg
https://i.imgur.com/cdfG1tb.jpeg
BreezyCarp
#6 Post by BreezyCarp » Sat Jul 04, 2026 4:52 am
OneDay wrote: Sat Jul 04, 2026 12:49 am Here are example of real and fake and if it is legit MT1959
Yeah, I saw that. Thanks.
RibShark
#7 Post by RibShark » Sun Jul 05, 2026 10:09 pm
BreezyCarp wrote: Sat Jul 04, 2026 4:34 am
Your drive is legitimate.
Hammerbo
#8 Post by Hammerbo » Wed Sep 02, 2026 7:28 pm
Thank you for the information. You helped me identify my drive as fake.
Makemkv says its MT1959
OS device name: F:
Current profile: BD-R SRM
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: KLQO3FE5734
Firmware version: 3.10
My BW-16D1HT has a large indent around the top sticker
Bottom rectangular sticker with misspelling "INTERFACE CONNECOTOR"
Manufactured in 2026 but has the address listed as "Li-Te Rd.,Peitou,Taipei"
This is the 2nd fake drive I've received from Newegg.
musashiwrx
#9 Post by musashiwrx » Tue Oct 13, 2026 8:01 pm
Got one off ebay (fake) today. I ordered on a whim before doing my research properly here. When i questioned the seller last week. they had already sent it but still gave me a refund immediately once i began asking probing questions. *whew* arrived today. Its a 2013 MT1939 with Dec 2023 Labels. and of course it's the circular indentation. Compared to my REAL MT1959 with 4 diagonal indents in the metal. This community saved my bacon. Thanks!
#10 Post by Billycar11 » Tue Oct 13, 2026 9:12 pm
musashiwrx wrote: Tue Oct 13, 2026 8:01 pm Got one off ebay (fake) today. I ordered on a whim before doing my research properly here. When i questioned the seller last week. they had already sent it but still gave me a refund immediately once i began asking probing questions. *whew* arrived today. Its a 2013 MT1939 with Dec 2023 Labels. and of course it's the circular indentation. Compared to my REAL MT1959 with 4 diagonal indents in the metal. This community saved my bacon. Thanks!
Please post the sellers info here viewtopic.php?t=42623
We can't let them keep getting away with this
musashiwrx
#11 Post by musashiwrx » Thu Oct 15, 2026 2:38 am
Good idea I'll post just the evidence as opposed to a direct statement of "this is a scam "that should speak for itself and people can analyze since I'm gonna be linking directly to eBay. Got all the pictures taken today trying to get them onto Google Drive so then I can get them onto here tomorrow good times
