NEW Single Drive Flasher - available worldwide!!
Re: NEW Single Drive Flasher - available worldwide!!
Post by MartyMcNuts » Sun Jul 05, 2026 12:29 am
Sayaka wrote: Sat Jul 04, 2026 1:09 pm Thank you. I am planning on trying your flasher on that odd WBacon drive with a BU50N inside (assuming I can get my hands on one eventually) should I have issues flashing it the normal way. :)
Ok, cool. If for some reason the drive model isn't recognised (the BU50N should be but it depends on the enclosure), so long as it is recognised as MT1959, you can still flash it.
On the rare occasion when a drive model itself may not being recognised but the drive platform is still recognised as MT1959, the app will provide the option to toggle between slim & desktop. You choose whichever the drive type is and then the applicable firmware options will be available to select from.
