Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Pumpkin
Re: Pioneer BDR-S09XLT LibreDrive ready but not ripping UHD-discs
Post by Pumpkin »
can my Pioneer be flashed ?
OS device name: M:
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.54
Serial number: XXXXXXXXXXXX
Firmware date: 2020-07-21
Drive platform: RS8600
Firmware version: 1.54/ID43
THX and BR
Pumpkin wrote: Wed Feb 25, 2026 9:35 pm Hi,
OS device name: M:
Revision: 1.54
THX and BR
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
levtrocki
Post by levtrocki »
Hello. Just got this drive:
OS device name: G:
Revision: 1.10
Serial number: MLDL002787WL
Firmware date: 2013-10-15
Firmware version: 1.10/ID43
Can this be flashed? Thanks <3
levtrocki wrote: Thu Mar 26, 2026 5:56 pm Hello. Just got this drive:
OS device name: G:
Revision: 1.10
see below for email
OS device name: G:
Revision: 1.10
Yes. I provide the flasher and only ask for a donation and no fee.
yapmkv
Post by yapmkv »
Coopervid wrote: Thu Mar 26, 2026 10:22 pm
OS device name: G:
Revision: 1.10
I have the same drive, can you PM me?
yapmkv wrote: Sat Mar 28, 2026 9:30 pm
OS device name: G:
Revision: 1.10
PM sent.
nexttoyou
Post by nexttoyou »
what a fascinating topic! For some inexplicable reason (laziness, I suppose), I completely missed all of this. Well, to make a long story short, I have the following three drives in my home:
The first and second one (only the serial number is different):
Revision: 1.51
Serial number: 000000000000
Firmware date: 2018-05-08
Highest AACS version: 81
Drive platform: RS8601
Firmware version: 1.51/ID43
The third one:
Product: BD-RW BDR-XU03
Revision: 1.03
Firmware date: 2015-06-29
Bus encryption flags: 13
Drive platform: RS8520
Firmware version: 1.03
I have no idea if that matters, but we only have two Macs (one with an Intel chip and one with an Apple/ARM chip) and no Windows systems. Would that work?
nexttoyou wrote: Sun Jun 28, 2026 5:46 pm Hi,
Revision: 1.51
The third one:
Revision: 1.03
You need windows or a VM for it to work
Sure email me that drive info section see below for email
Revision: 1.51
The third one:
Revision: 1.03
PM sent for your 209. The other one isn't flashable for UHD:
nexttoyou
Post by nexttoyou »
Coopervid wrote: Sun Jun 28, 2026 9:19 pm PM sent for your 209. The other one isn't flashable for UHD:
Thank you very much! It all looks pretty simple. I'm going to use a VM on my iMac (Intel) for this.
Just one more question: the two BD-RW BDR-S09 drives are in an external enclosure from OWC (Mercury Pro). As I understand it, the process works without any problems with this enclosure, right?
THX!
nexttoyou wrote: Mon Jun 29, 2026 1:06 pm
THX!
Correct.
black_raven
Post by black_raven »
found this thread and understood that maybe not all hope is lost for my old Pioneer BDR-S09XLT :)
It was my first UHD drive but after negative answer from official Pioneer support about reading 4K discs I put it back in the box and bought Asus :(
Would anyone please help me with the magical firmware needed for 4K discs reading?
Thank you very much in advance
OS device name: F:
Revision: 1.32
Serial number: OEDLXXXXXXWL
Firmware date: 2015-08-25
Highest AACS version: 61
Firmware version: 1.32/ID43
AM6B+ Coreelec, OPPO UDP-203, Asus PC BW-16D1HT
black_raven wrote: Sat Jul 04, 2026 4:47 am Hi,
OS device name: F:
Revision: 1.32
see below for email
OS device name: F:
Revision: 1.32
PM sent.
