Leave it alone unless you are having UHD read issues. Not worth flashing it otherwise as you don't gain anything.black_raven wrote: Fri Jul 03, 2026 9:13 pm Hi, have my ASUS BW-16D1HT with the following firmware for many years.
Looking for advice whether there is some newer version worth flashing?
Use the drive mostly for ripping my CD and BD/UHD collection...thanks
Drive Information OS device name: W: Manufacturer: ASUS Product: BW-16D1HT Revision: 3.02 Serial number: KEJIXXXXXXX Firmware date: 2117-11-24 14:13 Bus encryption flags: 1F Highest AACS version: 61 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Original (unpatched) Firmware version: 3.02 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
black_raven
Thank you for the advice, will leave it alone then
The only small issue I experience is that "Exact Audio Copy" (EAC) is reporting the drive is unable to successfully detect C2 Errors during audio CD ripping. But nothing indicates that the newer firmware 3.10MK improves this.
AM6B+ Coreelec, OPPO UDP-203, Asus PC BW-16D1HT
