black_raven wrote: Fri Jul 03, 2026 9:13 pm Hi, have my ASUS BW-16D1HT with the following firmware for many years.
Looking for advice whether there is some newer version worth flashing?
Use the drive mostly for ripping my CD and BD/UHD collection...thanks
OS device name: W:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: KEJIXXXXXXX
Firmware date: 2117-11-24 14:13
Bus encryption flags: 1F
Highest AACS version: 61
Firmware version: 3.02
Leave it alone unless you are having UHD read issues. Not worth flashing it otherwise as you don't gain anything.
black_raven
Post by black_raven »
Thank you for the advice, will leave it alone then 8)
The only small issue I experience is that "Exact Audio Copy" (EAC) is reporting the drive is unable to successfully detect C2 Errors during audio CD ripping. But nothing indicates that the newer firmware 3.10MK improves this.
AM6B+ Coreelec, OPPO UDP-203, Asus PC BW-16D1HT
