Problem with external LG WP50NB40
Re: Problem with external LG WP50NB40
#16 Post by MartyMcNuts » Fri Dec 05, 2025 3:27 am
Jarom wrote: Thu Dec 04, 2025 10:12 pm Sorry to ask: But what is the difference between
  • BP50NB40-NB40-1.00-Clean.bin.zip
  • DE_LG_BU40N_1.00
BP50NB40-NB40-1.00-Clean.bin is for silly people that have flashed their older, incompatible BP50NB40 SVC NB40 drive and are trying to unbrick it.
LG BU40N 1.00 is the original firmware for the official UHD drive, LG BU40N.
MikeMike
#17 Post by MikeMike » Sun Jan 04, 2026 1:46 pm
MartyMcNuts wrote: Sat Dec 03, 2022 7:19 am
scarpogre wrote: Fri Dec 02, 2022 2:34 am Hello everyone.
I have an external lg drive WP50NB40 svc Code NB40. I made a big mistake flashing it with the MK firmware pack for UHD. I flashed it with the MK Firmware WP50NB40-NB50. Now the drive is a brick I cannot find the original firmware to get make my drive work again. Can anyone share a link to the original firmware or is there another way to get this drive to work again?
Thanks for any help
Can you try this and let us know if it works. Please download the attached firmware file.
1. Using SDFtool Flasher, select your drive
2. Select RECOVERY mode
3. In the popup window select the current firmware that is on the drive (whatever you flashed it to) -
4. In the firmware drop down box select the attached firmware (which is the original BP50NB40 (NB40) 1.00 firmware)
5. Press START.
Let us know what happens.
I have the similar problem. How I can flash my Slim Drive ? Do I need the old firmware ? How to get it ?
I created the Dump File -? dump_user_HL-DT-ST_BD-RE_BP55EB40_1.03_212005070924_SIKZZICNI2648
I had this (1.03) firmware form the manufacturer website.
MikeMike
#18 Post by MikeMike » Sun Jan 04, 2026 2:28 pm
venospls
#19 Post by venospls » Fri Jul 03, 2026 5:46 am
Thanks for any help
5. Press START.
I hate to revive an old topic. But due to my misunderstanding I also ended up in the same boat as OP. Is it possible to get the attached 1.00 Firmware again? I'd like to attempt to recover my WP50NB40 NB40. Thanks!
#20 Post by MartyMcNuts » Fri Jul 03, 2026 10:39 pm
venospls wrote: Fri Jul 03, 2026 5:46 am
Thanks for any help
5. Press START.
First post of SDFtool, flasher thread.
Sayaka
#21 Post by Sayaka » Fri Jul 03, 2026 10:57 pm
Personally, I am getting a "The selected attachment does not exist anymore." error when clicking on the download link for that firmware.
#22 Post by MartyMcNuts » Fri Jul 03, 2026 11:08 pm
Sayaka wrote: Fri Jul 03, 2026 10:57 pm Personally, I am getting a "The selected attachment does not exist anymore." error when clicking on the download link for that firmware.
Perhaps, the Admins removed it. There were far too many attachments cluttering up the forum and making it almost unusable.
venospls
#23 Post by venospls » Fri Jul 03, 2026 11:12 pm
MartyMcNuts wrote: Fri Jul 03, 2026 10:39 pm
5. Press START.
Yes sir, I did check there as well. Seems the file has been removed?
Sayaka
#24 Post by Sayaka » Fri Jul 03, 2026 11:17 pm
Huh. Well, would you look at that. For some reason, I had it on my computer. No idea why, since I don't need it and probably never will. Anyway : https://mega.nz/file/mnwHlbbS#mphALHyxo ... j37GAxoxLU
venospls
#25 Post by venospls » Fri Jul 03, 2026 11:44 pm
That is pretty nifty lol. Thanks for the upload. Now let's see if I can get this thing working again.
edit: and it worked! Thanks again!
FoggyKarl
#26 Post by FoggyKarl » Tue Jul 21, 2026 4:18 am
Hi Everyone,
Thanks for making this flasher and tools available. Best Job done!
I'm in exactly the same situation, but the firmware link to revert from this thread doesn't work. Please could someone post the file again?
I've tried the 2 flash combos a few different ways. I did dump the firmware before I started, but the files are nothing like the .bin file used to flash the drives. After the first flash I saw the green light, MakeMKV saw the drive. It went from unpatched with support to capability recovered with patch (sorry I'm going from memory and I'm not getting any younger), but it never would make a sound or open. If I paperclipped it, the drive would spring open and MakeMKV would show that it was open. Close it and it showed it closed. I've even tried different combinations of the USB cables, but no luck.
Thanks again for the effort and I'm happy for everyone this has worked for. I'd really appreciate any assistance.
Sayaka
#27 Post by Sayaka » Tue Jul 21, 2026 1:40 pm
This download link works for me : https://mega.nz/file/mnwHlbbS#mphALHyxo ... j37GAxoxLU
