I bought Elysium on 4k, ripped it.
At around 40.42. it was an error. See attached image.
I cleaned the disc and ripped again, same result.
It only last a second or two, but I'm a bit anal, so I found it irritating.
I return the disc, and got a new one. Same result.
I live in Europe, so maybe it was just the European version? Bought the US version. Same result.
Not surprising, probably the same print, just different subtitles and other minor differences.
I also downloaded different versions, all with the same result.
Have anybody else experienced the same issue?
Thanks.
Image: https://www.dropbox.com/scl/fi/ngpcbyy8 ... 8vehf&dl=0
Elysium: Is this error on all discs?
Re: Elysium: Is this error on all discs?
I only have the regular blu-ray and the thing you're referencing happens at about 00:42:40. And I think it is supposed to be there. It is the "glitch" of the video feed starting up for the guy watching a wall of monitors.
Hufse
Yes, of course.
The guy actually says "the camera is live boys".
How could I miss that... Embarrassing..
Thank you so much!
You rule!
Thank you so much!
You rule!
