Ubuntu VLC use MakeMKV
chihwahli
Post by chihwahli » Tue Jun 30, 2026 4:58 pm
The instructions in here are to vague. I really have no clue where to execute the command to create an symbolic link.
I do not care if I have double the same files, I just need it to work.
viewtopic.php?f=10&t=7008
I installed MakeMKV with the instructions:
viewtopic.php?t=224
my file location: /usr/lib/libmmbd.so.0
In this directory inside terminal , I execute command: sudo ln -s libmmbd.so.0 /usr/lib/
I get message: ln: Already exists
Please someone. Where must I execute this command, or is there an alternative way to solve this? The instructions are really not clear. I am just a user, instructions must be crystal clear.
Sayaka
Re: Ubuntu VLC use MakeMKV
Post by Sayaka » Tue Jun 30, 2026 7:45 pm
Please try this instead :
Open a terminal inside the /usr/lib folder (as you previousy did)
Then :
sudo rm libaacs.so.0 libbdplus.so.0
Ignore any error messages, this is just a precaution to remove any faulty links, just in case.
Then, in the same terminal and the same folder :
sudo ln -vs libmmbd.so.0 libaacs.so.0
and then, also in the same terminal and the same folder :
sudo ln -vs libmmbd.so.0 libbdplus.so.0
tomty89
Post by tomty89 » Tue Jun 30, 2026 7:48 pm
You shouldn't need to create the symlink unless you have some ancient system / libbluray though.
What you better make sure / check beforehand is that MakeMKV can work (rip to MKV / make decrypted backup). For example, you need to "register" first, as in, entering beta / permanent key to "activate' all functons, or start the trial period. Also, for UHD BD / non-LibreDrive, Hashed Keys need to be downloaded (it might be slow / fail because of geoblocking). sdf.bin update stalling might also prevent it from working.
In other words, make ripping / decrypted backup attempt before you play directly. (You can stop it once you see the main content being ripped.)
Sayaka
Post by Sayaka » Tue Jun 30, 2026 7:57 pm
tomty89 wrote: Tue Jun 30, 2026 7:48 pmYou shouldn't need to create the symlink unless you have some ancient system / libbluray though
On my Noble Numbat-based distro, I most certainly did need both symlinks.
EDIT : Please note that it's also not recommended to use your Blu-ray drive to play discs directly in a repeated manner, as this will cause unnecessary laser wear-and-tear. On the other hand, my guess is that if you have, say, a ton of Blu-ray discs from a TV series that you couldn't possibly rip because you lack the storage space needed for all of them, then you might want to go for it.
Overlap3470
Post by Overlap3470 » Tue Jun 30, 2026 8:00 pm
I'm using the flathub version.
It installs to:
/var/lib/flatpak/app/com.makemkv.MakeMKV
The lib is in:
/var/lib/flatpak/app/com.makemkv.MakeMKV/current/active/files/lib/libmmbd.so.0
Soo the command would be:
sudo ln -s /var/lib/flatpak/app/com.makemkv.MakeMKV/current/active/files/lib/libmmbd.so.0 /usr/lib/libmmbd.so.0
that will create a symlink (shortcut) that points from your lib folder to the lib itself.
tomty89
Post by tomty89 » Tue Jun 30, 2026 8:17 pm
Sayaka wrote: Tue Jun 30, 2026 7:57 pm
No idea. Apparently the last non-Windows libmmbd commit dates back to 2017 (1.0.2), with 1.3.4 being the version Noble ships. A quick check doesn't seem to show that the libmmbd loading logic is being patched out or disabled whatsoever in Ubuntu.
EDIT: although IIRC under certain cirumstances libaacs could "stall" instead of just "fail", in which case would prevent libmmbd from "kicking in". (To be frank, instead of overwriting the files with symlinks, uninstalling libaacs and libbdplus properly might be a better thing to do -- should be possible for "Recommend"?)
Sayaka
Post by Sayaka » Tue Jun 30, 2026 8:38 pm
Good point - I assumed this to already be the case for chihwahli, but I probably should have mentioned that to them. The reason I posted this :
was more in the very unlikely case chihwahli could have, say, manually created faulty links due to typos or something before reading my post. Just a silly precaution on my part, really.
EDIT :
It's not just Ubuntu, it would seem. Even with my Arch distrobox with Kodi, VLC and MakeMKV, direct 4K Blu-ray disc playback wouldn't work before I created the symlinks...
tomty89
Post by tomty89 » Tue Jun 30, 2026 9:43 pm
Well it definitely worked / works for me on Arch, but my experience is with mpv and bd_info only. (I'm not sure if the player / frontend could matter though.) Also mainly of encrypted backup instead of direct disc playback (but I definitely tested the latter once -- could be just regular BD though).
Sayaka
Post by Sayaka » Tue Jun 30, 2026 10:36 pm
Interesting. May I ask how you installed MakeMKV on Arch ? Normal download/compile/install straight from the forums, or something else?
tomty89
Post by tomty89 » Tue Jun 30, 2026 10:56 pm
The AUR package. (Not so different from make and make install, except it is packaged for pacman first -- well makepkg might do something in addition like "stripping" whatsoever?)
Sayaka
Post by Sayaka » Tue Jun 30, 2026 11:08 pm
Understood, thank you for the reply. I may have a closer look at this later.
h7t7w
Post by h7t7w » Mon Jul 06, 2026 9:18 pm
I'm considering installing SteamOS after Extended Support for Windows 10 ends. Would this method work to use MakeMKV to play Blu-rays with Kodi? As I understand it, SteamOS can only install flatpaks.
Sayaka
Post by Sayaka » Mon Jul 06, 2026 10:35 pm
I try not to use flatpak too much, so I cannot answer this just yet. However, I will say that this :
is probably not true as there seems to be a way to disable Steam's "read-only" mode in order to be able to use Arch's package manager. However, people have complained that SteamOS updates sometimes invalidated the changes they had made to the system.
h7t7w
Post by h7t7w » Mon Jul 06, 2026 11:08 pm
I'm sure there's probably a way, I'm just trying to avoid tinkering as much as possible (would even purchase a license instead of using the beta key in pursuit of that goal). I want my PC to play games and the occasional concert video.
Hence the minimal tinkering desire
Sayaka
Post by Sayaka » Tue Jul 07, 2026 6:45 am
I am not sure using flatpak would be "avoiding tinkering" in this particular case, but I will try to answer your original question as soon as possible (most likely today or tomorrow). If I can find the time I will try a SteamOS virtual machine for a full test, and if not I will just use the flatpak manager on my own distro.
EDIT : Apologies for being slow, I still want to take care of this but I have been sick due to the heat wave in my country.
