error ih makemkv
babayaga
error ih makemkv
Post by babayaga »
MMakeMKV v1.18.3 win(x64-release) started
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading 'BD-RE PIONEER BD-RW BDR-XD06U 1.11 NIDL001216JP' at offset '33364246528'
Error 'Scsi error - MEDIUM ERROR:POSITIONING ERROR DETECTED BY READ OF MEDIUM' occurred while reading 'BD-RE PIONEER BD-RW BDR-XD06U 1.11 NIDL001216JP' at offset '33364310016'
udf: node fe/efe failed!
Using LibreDrive mode (v02.1 id=A16AD1CAFF11)
Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading 'BD-RE PIONEER BD-RW BDR-XD06U 1.11 NIDL001216JP' at offset '33364310016'
Using Java runtime from C:\Program Files\Eclipse Adoptium\jdk-25.0.3.9-hotspot\bin\java.exe
Title #01077.mpls has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01245.mpls was added as title #0
File 01258.mpls was added as title #1
File 00149.mpls was added as title #2
Title 00040.mpls is equal to title 01258.mpls and was skipped
Title #01072.mpls has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00509.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00510.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00511.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00512.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00513.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00514.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00515.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00516.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00505.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00517.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00518.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00519.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00520.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00521.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00506.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00507.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00500.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00501.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00508.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00522.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00523.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00524.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00525.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00526.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00527.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00528.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00529.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00530.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00531.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00532.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00533.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00534.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00535.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01081.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01086.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01087.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01090.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01093.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01096.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01099.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01104.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01105.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01114.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01161.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01194.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01213.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01214.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01215.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01251.mpls was added as title #3
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00676.m2ts' at offset '0'
Title #01252.mpls was skipped
zittrig
Re: error ih makemkv
Post by zittrig »
Ripping was fine though? Or the ripping process didn't start?
I had also errors with this drive series after flashing to BDR-XD06U 1.11 but the ripping processes ended in a success.
But I can't say if this is the same error.
