Post by MartyMcNuts » Sun Jun 28, 2026 7:02 am
Crotalus wrote: Sun Jun 28, 2026 2:52 am
MartyMcNuts wrote: Sun Jun 28, 2026 2:43 am You might have been lucky and got an older one, before they changed something in the enclosure that stops flashing and libredrive from working.
I ordered it last week, it arrived today. I bought this one because someone on reddit mentioned it'd worked for them. It worked for me too. Don't know what else to tell you. I only had the one UHD movie, but I ordered a couple more so I'll reply here if it suddenly stops working or something.
I placed the Amazon order after I made my original post asking for recommendations, since I ordered a drive that was supposed to work according to the OP, but did not.
Back in about July 2025, they changed something in the enclosure that stops flashing and libredrive from working. You must have received one made before this change.
kahl1
pioneer laufwerk keine aktualisierung
Post by kahl1 » Sun Jun 28, 2026 8:23 am
guten, habe software gekauft und laufwerk, keine auto-aktualisierung hier die daten
Ich verwende MakeMKV Version v1.18.3 und sehe, dass LibreDrive zwar als möglich, aber noch nicht aktiviert angezeigt wird. Ich wäre für jede Hilfe sehr dankbar. Laufwerksinformationen
OS-Gerätename: G:
Produzent: PIONEER
Produkt: BD-RW BDR-XD07U
Revision: 1.00
Serienummer: RCDL003624JP
Firmware-Datum: 2017-10-30
Highest AACS version: 61
Drive platform: RS8D31
Firmware version: 1.00/ID69
Keine Disk eingelegt
MakeMKV v1.18.3 win(x64-release) gestartet
Lade aktuelle SDF in C:\Users\alfre/.MakeMKV ...
Automatisches Herunterladen von SDF ist deaktiviert oder fehlgeschlagen.
Post by Billycar11 » Sun Jun 28, 2026 12:27 pm
what port is on your on the drive side micro b 3.0 or usb C?
Re: pioneer laufwerk keine aktualisierung
Post by Billycar11 » Sun Jun 28, 2026 12:38 pm
kahl1 wrote: Sun Jun 28, 2026 8:23 am
your issue is that
unblock russia if you have that blocked in your firewall
or use keydb see uhd disc section for that
Crotalus
Post by Crotalus » Sun Jun 28, 2026 5:52 pm
Billycar11 wrote: Sun Jun 28, 2026 12:27 pm
USB C
MartyMcNuts wrote: Sun Jun 28, 2026 7:02 am
Do you have a serial number from one of the ones that doesn't work?
BizzyB
Post by BizzyB » Sun Jun 28, 2026 10:07 pm
nicholfd wrote: Sat Jun 27, 2026 2:42 am
BizzyB wrote: Fri Jun 26, 2026 10:19 pm Honest question, with the supported drives being harder and harder to find, is anyone going to crack this nut for new drives or create something new that works? Or is this hobby going to slowly die as people's drives die? I've been trying to find a backup drive in case another one dies but can't find one anywhere.
I still l'have some drives on-hand, pre-flashed for 4K/UHD & MakeMKV. I have a few more coming, but my cost increased by $30+ USD for what's coming.
What I have available for purchase is linked in my signature.
Thanks,
Frank
I emailed you yesterday. Cheers.
nicholfd
Post by nicholfd » Sun Jun 28, 2026 10:12 pm
BizzyB wrote: Sun Jun 28, 2026 10:07 pm
Thanks,
Frank
Thanks - I just found a couple in junk e-mail. Replying now.
Thanks,
Frank
Post by Billycar11 » Mon Jun 29, 2026 12:22 am
Crotalus wrote: Sun Jun 28, 2026 5:52 pm
USB C
interesting im going to try mine again see if sdf was updated to get around the block or if their new stock has changed...
nicholfd
Post by nicholfd » Mon Jun 29, 2026 1:56 am
Billycar11 wrote: Mon Jun 29, 2026 12:22 am
USB C
I bought a slim-line USB DVD drive/chassis. Swapped the DVD drive to the Archgon, for ripping DVDs, and put the BU40N in the DVD chassis to flash & use.
kahl1
habe russland freigegeben
Post by kahl1 » Mon Jun 29, 2026 8:29 am
guten, habe russland freigegeben und dann
OS-Gerätename: G:
Produzent: PIONEER
Revision: 1.00
danach uhd bluray eingelegt und das war der erfolg
Fehler 'SCSI-Fehler - HARDWARE ERROR:4407' trat auf während des Auslesens von 'BD-RE PIONEER BD-RW BDR-XD07U 1.00 RCDL003624JP' bei Offset '2097152'
udf: node fe/efe failed!
Fehler 'SCSI-Fehler - HARDWARE ERROR:4407' trat auf während des Auslesens von 'BD-RE PIONEER BD-RW BDR-XD07U 1.00 RCDL003624JP' bei Offset '1507328'
Fehler 'SCSI-Fehler - HARDWARE ERROR:4407' trat auf während des Auslesens von 'BD-RE PIONEER BD-RW BDR-XD07U 1.00 RCDL003624JP' bei Offset '1568768'
Fehler 'SCSI-Fehler - HARDWARE ERROR:4407' trat auf während des Auslesens von 'BD-RE PIONEER BD-RW BDR-XD07U 1.00 RCDL003624JP' bei Offset '2228224'
nicholfd
Post by nicholfd » Tue Jun 30, 2026 12:53 am
seamus wrote: Fri Jun 26, 2026 3:32 am
NoMoreSorry wrote: Mon Jun 15, 2026 6:14 pm Hello, I am new here, wondering if my drive can be flashed to UHD. Any help would be greatly appreciated!
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: DDDL291769WL
Firmware date: 2023-04-20
Drive platform: RS8511
Firmware version: E102/ID26
Can I ask how you got all of this information... is there a command that "reads the drive" & writes it out?
TIA,
~S
Open the MakeMKV app, with a drive attached to the computer. it's right there in the top, right pane, titled "Info".
ShakyS
Post by ShakyS » Wed Jul 01, 2026 2:47 pm
i have an lg Drive Information
OS device name: F:
Product: BD-RE BP50NB40
Revision: 1.01
Serial number: SIKYVHB9K1750
Firmware date: 2117-11-23 16:15
Harware support: Yes
Firmware support: No
Firmware version: 1.01
how do i find the link to the gui sdf tool ? and the firmware pack ? thanks
nicholfd
Post by nicholfd » Wed Jul 01, 2026 7:03 pm
ShakyS wrote: Wed Jul 01, 2026 2:47 pm i have an lg Drive Information
OS device name: F:
Revision: 1.01
This thread: SDFtool Flasher
SiliconDragon
Post by SiliconDragon » Fri Jul 03, 2026 1:00 am
Just chiming in a bit in case the flash job I just did and the problems I encountered and worked around might help others...
I have an LG HL-DT-ST BD-RE WH16NS58DUP drive (the hybrid LG/HLDS duplicator model), an up-to-date Windows 11 PC, current MakeMKV, and just used SDFtool Flasher (v1.3.6.0) to flash the drive successfully. There WERE some problems, though:
1. SDFtool Flasher.exe said it couldn't find my copy of MakeMKV. No prob, mine's installed on the D drive, so I copied the whole folder to my C drive and reran the tool, problem solved.
2. The flash job ran for about 20 seconds, the status said "100% Operation finished. Please wait...", then coughed up the following error popup: "ERROR: Command produced error code 0x82062900". Assuming it was some post-check, I clicked OK, closed the tool, and restarted my PC, powering off just before the POST screen, waited 60s, powered on, logged in, launched MakeMKV, and confirmed that the firmware flashing was flawless.
If anyone else runs into the installation drive issue or that error code, I hope this helps.
OS device name: N:
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: (redacted)
Highest AACS version: 50
Firmware version: 1.02
PS My firmware file used is DE_LG_WH16NS60_1.02_MK.bin from the "All You Need..." zip file.
PPS Claude.ai said it'd scanned this forum and found someone else who had the same error which was fixed with a 2nd flashing, and I was prepared to do that if my post-restart info showed that the flash didn't take.
black_raven
Post by black_raven » Fri Jul 03, 2026 9:13 pm
Hi, have my ASUS BW-16D1HT with the following firmware for many years.
Looking for advice whether there is some newer version worth flashing?
Use the drive mostly for ripping my CD and BD/UHD collection...thanks
OS device name: W:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.02
Serial number: KEJIXXXXXXX
Firmware date: 2117-11-24 14:13
Bus encryption flags: 1F
Firmware version: 3.02
AM6B+ Coreelec, OPPO UDP-203, Asus PC BW-16D1HT
