Crotalus wrote: Sun Jun 28, 2026 2:52 am
MartyMcNuts wrote: Sun Jun 28, 2026 2:43 am You might have been lucky and got an older one, before they changed something in the enclosure that stops flashing and libredrive from working.
I ordered it last week, it arrived today. I bought this one because someone on reddit mentioned it'd worked for them. It worked for me too. Don't know what else to tell you. I only had the one UHD movie, but I ordered a couple more so I'll reply here if it suddenly stops working or something.
I placed the Amazon order after I made my original post asking for recommendations, since I ordered a drive that was supposed to work according to the OP, but did not.
Back in about July 2025, they changed something in the enclosure that stops flashing and libredrive from working. You must have received one made before this change.
kahl1
pioneer laufwerk keine aktualisierung
Post by kahl1 »
guten, habe software gekauft und laufwerk, keine auto-aktualisierung hier die daten
Ich verwende MakeMKV Version v1.18.3 und sehe, dass LibreDrive zwar als möglich, aber noch nicht aktiviert angezeigt wird. Ich wäre für jede Hilfe sehr dankbar. Laufwerksinformationen
OS-Gerätename: G:
Produzent: PIONEER
Produkt: BD-RW BDR-XD07U
Revision: 1.00
Serienummer: RCDL003624JP
Firmware-Datum: 2017-10-30
Highest AACS version: 61
Drive platform: RS8D31
Firmware version: 1.00/ID69
Keine Disk eingelegt
MakeMKV v1.18.3 win(x64-release) gestartet
Lade aktuelle SDF in C:\Users\alfre/.MakeMKV ...
Automatisches Herunterladen von SDF ist deaktiviert oder fehlgeschlagen.
what port is on your on the drive side micro b 3.0 or usb C?
Re: pioneer laufwerk keine aktualisierung
kahl1 wrote: Sun Jun 28, 2026 8:23 am
your issue is that
unblock russia if you have that blocked in your firewall
or use keydb see uhd disc section for that
Crotalus
Post by Crotalus »
Billycar11 wrote: Sun Jun 28, 2026 12:27 pm
USB C
MartyMcNuts wrote: Sun Jun 28, 2026 7:02 am
Do you have a serial number from one of the ones that doesn't work?
BizzyB
Post by BizzyB »
nicholfd wrote: Sat Jun 27, 2026 2:42 am
BizzyB wrote: Fri Jun 26, 2026 10:19 pm Honest question, with the supported drives being harder and harder to find, is anyone going to crack this nut for new drives or create something new that works? Or is this hobby going to slowly die as people's drives die? I've been trying to find a backup drive in case another one dies but can't find one anywhere.
I still l'have some drives on-hand, pre-flashed for 4K/UHD & MakeMKV. I have a few more coming, but my cost increased by $30+ USD for what's coming.
What I have available for purchase is linked in my signature.
Thanks,
Frank
I emailed you yesterday. Cheers.
nicholfd
Post by nicholfd »
BizzyB wrote: Sun Jun 28, 2026 10:07 pm
Thanks,
Frank
Thanks - I just found a couple in junk e-mail. Replying now.
Thanks,
Frank
Crotalus wrote: Sun Jun 28, 2026 5:52 pm
USB C
interesting im going to try mine again see if sdf was updated to get around the block or if their new stock has changed...
nicholfd
Post by nicholfd »
Billycar11 wrote: Mon Jun 29, 2026 12:22 am
USB C
I bought a slim-line USB DVD drive/chassis. Swapped the DVD drive to the Archgon, for ripping DVDs, and put the BU40N in the DVD chassis to flash & use.
