eBay China BDR-212DBK??
slavik19
Post by slavik19 » Sat Jun 27, 2026 4:15 pm
Has anyone bought Chinese BDR-212DBK
Having issues with my LG drives
https://www.ebay.com/itm/800126119694?_ ... R5SQy53hZw
OneDay
Re: eBay China BDR-212DBK??
Post by OneDay » Sat Jun 27, 2026 9:47 pm
slavik19 wrote: Sat Jun 27, 2026 4:15 pm Has anyone bought Chinese BDR-212DBK
Do not buy from China. They show a legit Pioneer drive so you buy thinking your getting that drive but you end up with a re case unit that has a old used drive or probably a rma return. Check out the local forum sellers. Yes you will have to pay more but at least it legit with warranty.
This ebay link is what you will get. Notice the case is not like the real Pioneer case.
https://ebay.io/m/ZxDflr
CarlJM
Post by CarlJM » Mon Jun 29, 2026 5:54 am
I'm Chinese. I once got scammed and bought a counterfeit BDR-S08XLB. The scammers run a ring specializing in refurbished knockoffs. They cheat buyers on both second-hand and official shopping platforms in China. These fake Pioneer drives are not worth buying at all.
OneDay
Post by OneDay » Tue Jun 30, 2026 3:35 am
Checkout this seller from Japan
https://ebay.io/m/n3PQ5K
