CANT_LOCATE_MAKEMKVCON in 1.18.4
52bickman
Post by 52bickman »
I get an error on startup "Application failed to initialize CANT_LOCATE_MAKEMKVCON" in 1.18.4. The compile and install was clean. I don't get that error on 1.18.3.
I'm running on Debian 13 x86_64 with Kernel 6.12.94. I searched around for solutions which indicated that there is an omission from the LD_LIBRARY_PATH that is needed, but doing an ldd on /usr/bin/makemkv and /usr/bin/makemkvcon doesn't reveal any unlinked libraries. I'm on the latest libavcodec version 7:7.1.5-0 from Debian.
tomty89
Re: CANT_LOCATE_MAKEMKVCON in 1.18.4
Post by tomty89 »
You mean like you see a popup window or so with that error when you try to start the MakeMKV GUI? Does running makemkvcon from a terminal give you any error?
How exactly do you compile and install? Manually? PPA?
16442496
Post by 16442496 »
Works just fine here. Compiled from sources.
viewtopic.php?t=224
GUI version works and TUI from Terminal works.
MakeMKV 1.17.6
+ gddrescue
