LG WH16NS60 issues
FortunatelyUnlucky
LG WH16NS60 issues
Post by FortunatelyUnlucky » Tue Jun 23, 2026 4:30 pm
how's it goin everyone. thank you for the forum and the abilities. I just purchased an lg wh16ns60 (cross flashed wh14ns40). I'm looking to use it with the omni drive flash. ive gotten this far, but I'm having an issue finding the SDFtool Flasher or which to use. further I'm going to accomplish this with win 11, but m also curious how i would do it with Linux, i run cachyos for a lab and bazzite for my rig. anyway i was hoping someone had a good recent write up or even if someone wanted to coach me with the process. thanks
tomty89
Re: LG WH16NS60 issues
Post by tomty89 » Tue Jun 23, 2026 8:55 pm
There's no special flasher for OmniDrive firmware. You don't need one.
"SDFTool Flasher", aka the GUI wrapper of sdftool is Windows only. (Maybe it can be made to work through wine but IIRC it's a .NET program so it could be a bit of a hassle -- my wine knowledge is old though.) I think you can use it to flash the OmniDrive firmware (if it works for your drive) too, since it's just a wrapper of sdftool and OmniDrive is just stock ASUS/LG firmware with a bit of modifcations, similar to MK firmware.
The CLI sdftool as a part of MakeMKV is available on Linux though. And it is at least currently the recommended tool for flashing OmniDrive.
I don't think you need any special "process" or "write up" if your drive is already flashed with an MK firmware. You should be able to just flash OmniDrive without any special instructions / arguments. There is information on http://wiki.redump.org/index.php?title=OmniDrive though (but it seems to be down at the moment.)
Sayaka
Post by Sayaka » Tue Jun 23, 2026 9:33 pm
The Wayback Machine is your friend : https://web.archive.org/web/20260616010 ... =OmniDrive
So, because your drive is not a slim drive, I believe you need to flash this firmware : https://archive.org/download/OmniDrive_ ... iDrive.bin
You may wish to wait for a firmware expert such as Marty or Billy to confirm the safety of this operation though. :)
If you need a download link for SDFTool Flasher, you can find the download links for it here : viewtopic.php?t=22896
(In your case you would just WRITE the firmware directly.)
As for Linux, something like this should work :
makemkvcon f -d /dev/sr0 rawflash main -i /path/to/ASUS_BW-16D1HT_3.02_OmniDrive.bin
Replace "/dev/sr0" with the correct path to your device (if needed) and replace "/path/to/" with the correct path to the folder where your firmware is.
Do be careful though, as you will be trying to flash Asus firmware to an LG drive :
In some cases crossflashing an Asus drive to an LG or the other way around you may no longer be able to burn disks-SamuriHL
FortunatelyUnlucky
Post by FortunatelyUnlucky » Fri Jun 26, 2026 11:24 pm
So I was a little upset with this forum because I didn't think I got any replies to my post. Since posting, I figured it all out and today I checked and noticed there were replies. So, thank you for those who tried to help, I ran into a couple of problems with where I was finding certain files and how to use sdftool. At this point im trying to figure out how to make certain games not super dark ie, twd survival instinct. But I don't think this is the place for that. So thank you again.
