I emailed the generated MKB20_v65_Mission-_Impossible_Fallout_35EF.tgz file. I updated KEYDB.cfg right before attempting the copy. I will update again in a bit and try then. Thanks!
UHD Mission: Impossible - Fallout
keydb_helper
Re: UHD Mission: Impossible - Fallout
Dartellum wrote: Fri Jun 26, 2026 7:56 pm Hello,
If you would like to see these discs added to the public keydb, please post links to the required files in the Public KeyDB Submissions thread.Dartellum wrote: Fri Jun 26, 2026 8:09 pm Hello,
I emailed MKB20_v61_Valerian_And_The_City_of_a_Thousand_Planets_3F2B.tgz. I updated KEYDB.cfg right before attempting the copy.
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
