In need of a compatible firmware and flashing solution for my Asus BW-16D1X-U
kevin2pop
Post by kevin2pop »
Hi, I've recently purchased an external blu-ray drive (ASUS BW-16D1X-U) and when I was trying to flash it before ripping the BD-RE XL disk, it came across a red cross next to MT1959 platform and the encrypted firmware was not displaying after I chose the firmware (DE_ASUS_BW-16D1HT_3.10_MK.bin) to write, my Drive and LibreDrive information are as follow:
OS device name: G:
Current profile: BD-RE
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number: DEDL113599WL
Firmware date: 2020-07-21
Drive platform: RS8F00
Firmware version: E113/ID76
Can you please provide me a compatible firmware and flasher that works for my external drive?
Thanks in advance!
Re: In need of a compatible firmware and flashing solution for my Asus BW-16D1X-U
kevin2pop wrote: Sun Jun 21, 2026 7:44 am Hi, I've recently purchased an external blu-ray drive (ASUS BW-16D1X-U) and when I was trying to flash it before ripping the BD-RE XL disk, it came across a red cross next to MT1959 platform and the encrypted firmware was not displaying after I chose the firmware (DE_ASUS_BW-16D1HT_3.10_MK.bin) to write, my Drive and LibreDrive information are as follow:
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Thanks in advance!
sure email me that info and
all others email me no need to post your info here publicly just reach out to me directly
see below for email
kevin2pop
Post by kevin2pop »
Billycar11 wrote: Sun Jun 21, 2026 8:05 am
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Thanks in advance!
see below for email
PM sent
NightHavoc
Post by NightHavoc »
I'm in dire need of a tool and firmware fort the below Asus drive (BW-16D1X-U). Have never doe this so looking for guidance :)
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: KLZP58I1627
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Highest AACS version: 58
NightHavoc wrote: Fri Jun 26, 2026 7:36 pm I'm in dire need of a tool and firmware fort the below Asus drive (BW-16D1X-U). Have never doe this so looking for guidance :)
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
see guide below or
email me or marty for the auto flasher
NightHavoc
Billycar11 wrote: Fri Jun 26, 2026 8:07 pm
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
see guide below or
So I found all the info needed for flashing the drive. One question I have is what would I loose with the patched software?
Will I still be able to write data onto discs like with the original A105 firmware? It doesn't seem much like a software issue but will I be able to burn M-discs like with the original one?
Will my write speeds be impacted and how much?
NightHavoc wrote: Fri Jun 26, 2026 9:34 pm
OS device name: G:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
see guide below or
most times you can still burn the same but sometimes no
NightHavoc
Billycar11 wrote: Fri Jun 26, 2026 10:40 pm
see guide below or
So in case I loose the ability to burn discs I'm stuck with this issue with no option tu turn back (I have not found any way to restore the original A105 firmware to the drive) or is there some failsafe other than the original firmware.
you could go back to BW-16D1H-U fw in the mk pack but it would be an older one but should work fine for burning
