How to enable libredrive on Pioneer UD04
Nova22
Post by Nova22 » Mon Jun 22, 2026 7:39 pm
i finally got a UD04 based of the 4k recommendation guide, but mine shows that the libredrive is not enabled and it cannot read 4k right not.
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.00
Firmware date: 2016-11-14
Highest AACS version: 82
Drive platform: Pioneer RS8A10
Firmware version: ID19
Re: How to enable libredrive on Pioneer UD04
Post by Coopervid » Tue Jun 23, 2026 10:18 am
Nova22 wrote: Mon Jun 22, 2026 7:39 pm i finally got a UD04 based of the 4k recommendation guide, but mine shows that the libredrive is not enabled and it cannot read 4k right not.
Revision: 1.00
PM sent.
Nova22
Post by Nova22 » Tue Jun 23, 2026 11:08 am
Coopervid wrote: Tue Jun 23, 2026 10:18 am
Revision: 1.00
PM sent.
Thank you!
do you know if I will need to update a BDR-XD05S? have one coming soon!
Post by Coopervid » Tue Jun 23, 2026 12:49 pm
Yes. We will make it UHD capable. :D
babayaga
Post by babayaga » Fri Jun 26, 2026 3:38 pm
Revision: 1.00
there were some bugs, but its correct
OS device name: F:
Product: BD-RW BDR-XD06U
Revision: 1.11
Serial number: NIDL001216JP
Firmware date: 2017-06-22
Drive platform: RS8B30
Firmware name: PIONEER BDR-XS06
Firmware version: 1.11/ID69
