BU4ON or funny firmware implant
cheesedzzzout
Post by cheesedzzzout »
Hi all,
I bought this driver off Taobao (Chinese e-commerce site) and have been using it for my normal blu-ray rips successfully.
I have some 4Ks that I wanted to try out, but the driver couldn't get pass the encryptions, so I believe it needs flashing and all.
Just curious if I actually got a BU4ON or its actually another driver with a firmware titled BU4ON inside, whether i should flash and risk a brick.
Below is the makeMKV details but what made me have this thought was that the back of the driver says the model is ECD819-Y. Honestly everything seems dodgy so I don't really know what to trust from this product. They could've used another case or something for all I know hahahaha
Product: BD-RE BU40N
Revision: A102
Serial number: M83J4MF4119
Firmware date: 2117-12-01 17:08
Bus encryption flags: 1F
Highest AACS version: 82
Not sure if its a cable issue, because there is also no liner for Libredrive and using the SDFtool flasher says MTI1959 platform is not available (needs direct SATA connection to detect?).
https://imgur.com/glvFYl8
https://imgur.com/a/XPiryk7
https://imgur.com/a/fPm302L
I'll probably just get a 4K ready ripper if this situation is too complicated, thanks and much appreciated!
Re: BU4ON or funny firmware implant
Probably the case is preventing flashing
It probably is a bu40n
But it's 100% not a pioneer so annoying that they do this
