1. When I open a Blu-Ray, how do I save the title with the name I choose? It keeps saving as either "title002.mkv" or <name-of-movie_t00.mkv> or something like that.
2. With some movies, I get couple of titles with the same size but different number of chapter. How do I know which one to pick? I don't think my blu-ray player displays any chapter information like my DVD player.
Simple Questions
ogredeschnique
Re: Simple Questions
About the file names, it puts it into a folder named same as the Disk. That is really a non issue. You basically have to watch the title###.mkv file and manually name it accordingly.
About title chapter variance: You might put the disk into a proper player and observe the number of chapters in the title that the player selects for you.
Chetwood
Yeah, I'd also like to see the title output to a filename that's similar to the BD (folder) or at least have an option to automatically create the output folder if it doesn't exits.
doctorwhofan10
Does not matter if it puts it under a folder, I have to rename it every time and move it to my Movies folder. It is weird that it does not have that option. So it is kind of an issue.ogredeschnique wrote:About the file names, it puts it into a folder named same as the Disk. That is really a non issue. You basically have to watch the title###.mkv file and manually name it accordingly.
