How to backup PS3 media
cyberschlumpf
Post by cyberschlumpf »
I understood with a libredrive enabled BR drive I would be able to also backup PS3 BRs.
What do I need to do here?
The disk is recognized in Windows as a data bluray and also in MakeMKV, but after inserting the disc, nothing can be selected (the big icon, nor the backup menu).
Drive is a ASUS SBW-06D5H-U A102 edition (MT1959 LT internals), flashed today with SDRflasher and MK 1.03 BU40N firmware to enable libredrive capabilties.
Thank you.
Product: BD-RE BU40N
Revision: 1.03
Serial number: MO3P63J4959
Highest AACS version: 68
Firmware version: 1.03
Disc Information
Label: PS3VOLUME
Timestamp: 2011-10-24 17:49:08
Data capacity: 9.37 Gb
Disc type: BD-ROM
Number of layers: 1
tomty89
Re: How to backup PS3 media
Post by tomty89 »
This is really not a forum for question regarding that. The concern of MakeMKV / LibreDrive is really just BD-Video (and copy protection / encryption related to that, such as AACS).
P.S. most likely you can only do a block-based dump with something like dd, or maybe redumper (whatever it does). The OmniDrive github repo lists it as "Disc contents are encrypted, disc key is not retrievable". No idea how exactly you are supposed to back it up such that it can be useful in any sense.
Sayaka
Post by Sayaka »
I agree, but assuming the mods are fine with it I will respond nevertheless (it might prevent some people from asking the same thing in the future). https://wiki.rpcs3.net/index.php?title= ... on_3_games
The part you most want is "How to dump Disc games with a compatible Blu-ray drive on PC using PS3 Disc Dumper", scroll down to that part.
LibreDrive also has nothing to do with dumping PS3 discs, AFAIK. All that's needed for that particular task is a compatible drive model.
EDIT : And if you have any further questions, feel free to PM me directly, since this forum isn't really the place for PS3-related discussions.
cyberschlumpf
I'm sorry, I didn't mean to ask anything inappropriate. It just appeared to me, that using libredrive and the backup functionality of MakeMKV a true 1:1 copy could be made (for personal archival/disaster recovery!), which would otherwise maybe not possible with closed firmware drives.
Sayaka
Post by Sayaka »
PM sent.
qq1649536801
Post by qq1649536801 »
use onnidrive firmware, it dose support your drive
and fm also support makemkv, just flash it, but you MUST check your drive is silm version
