Backup fails but full rip succeeds
DavidGA
#1 Post by DavidGA » Wed Feb 25, 2026 7:25 am
I have a bunch of DVDs where attempting the "backup" function to make an ISO fails. The error message is simply "Backup failed", no other helpful info, even when using makemkvcon in debug mode.
However, if you do a normal rip, ripping every single title to an mkv file, even if you include every single stream, the rip succeeds.
What might cause that?
flojo
Re: Backup fails but full rip succeeds
#2 Post by flojo » Wed Feb 25, 2026 1:36 pm
I believe there's a silent bug or the supposed error is not being printed. I've gotten this on several UHD discs with makemkvcon. I've ripped the same discs again and have not received the error. Furthermore the file hashes are identical between the rips, so I simply ignore the error if the reading completes :-/
DavidGA
#3 Post by DavidGA » Wed Feb 25, 2026 5:33 pm
Unfortunately in my case the backup isn't successful, it bails out before it gets to the end of the disc.
mnatomizer
#4 Post by mnatomizer » Wed Jun 24, 2026 7:56 am
DavidGA wrote: Wed Feb 25, 2026 5:33 pm Unfortunately in my case the backup isn't successful, it bails out before it gets to the end of the disc.
Hi, sorry to reply to an old post but I had a very similar issue and was also able to create a full rip. I'm not sure what's causing it, but there's another report on it in this thread: viewtopic.php?t=35325
I was able to create a .iso backup of my disc with this issue with ImgBurn, if that helps anyone currently experiencing this issue.
