UHD ripping works, but extremely slow
I am new to UHD ripping. My drive is a Pioneer BDR-UD04 running LibreDrive. Ripping seems to work with no errors, but it's taking forever. Ripping Transformers (2007) took 8 days. I'm trying Lucy now, and MakeMKV is showing a read rate of 2.3 M/s (0.5X) and estimating 82 hours remaining. My discs look clean. Any suggestions? Thanks.
Re: UHD ripping works, but extremely slow
Try setting the drive to Performance mode.
Right click inside the MakeMKV program folder and open a PowerShell terminal (Windows only, see below for Linux)
Do the following the see the current drive speed setting :
or
Replace E: with your drive letter if it isn't the correct one (it could also be D: or F: and so on).
Once you have the drive speed, if it is not set to Performance, do the following :
or
Replacing E: with the correct drive letter as needed.
This should set the drive to Performance mode.
(For the record, I've just checked the values, 0 should be Default, 1 should be Performance, and 2 should be Quiet. 2 is for playing Blu-ray discs quietly with software such as Cyberlink, VLC or Kodi and should never be used for ripping.)
Also make sure that the drive is getting enough power, you might have gotten a USB-A to USB-C adapter with your BDR-UD04, don't be afraid to use that to connect the drive to a USB-C port on a laptop, for example.
If using Linux, do *not* use a makemkv-bin version newer than 1.17.7 and do this instead (this does not need to be done from a specific folder) :
or
Replacing /dev/sr0 with the correct device path as needed to get the drive speed.
Then, to set the drive speed mode to Performance :
or
Replacing /dev/sr0 with the correct device path as needed.
EDIT : Once you have done this, if you're on Linux, you can switch back to makemkv-bin-1.18.4 afterwards.
.\makemkvcon64.exe f -d E: -t pioneer speed getCode: Select all
.\sdftool64.exe -d E: -t pioneer speed getOnce you have the drive speed, if it is not set to Performance, do the following :
.\makemkvcon64.exe f -d E: -t pioneer speed set 1Code: Select all
.\sdftool64.exe -d E: -t pioneer speed set 1This should set the drive to Performance mode.
makemkvcon f -d /dev/sr0 -t pioneer speed getCode: Select all
sdftool -d /dev/sr0 -t pioneer speed getThen, to set the drive speed mode to Performance :
makemkvcon f -d /dev/sr0 -t pioneer speed set 1Code: Select all
sdftool -d /dev/sr0 -t pioneer speed set 1EDIT : Once you have done this, if you're on Linux, you can switch back to makemkv-bin-1.18.4 afterwards.
Thank you, Sayaka, for this guide. It may be very useful.
In case of the issue described by the author of the thread, it seems to me that the drive doesn't have sufficient power.
Try to get a USB‑C to USB‑A 3.0 and USB‑A 2.0 Y‑cable and connect both ends to the USB ports.
A good solution, and the one I recommend is to buy a USB 3.0 hub with an external power supply.
Looking for a Pioneer 4K UHD drive?
Click here
Click here
Thanks, I'll try this tonight.Sayaka wrote: Tue Jun 23, 2026 12:51 pm Try setting the drive to Performance mode.
orCode: Select all
Replace E: with your drive letter if it isn't the correct one (it could also be D: or F: and so on).Code: Select all
orCode: Select all
Replacing E: with the correct drive letter as needed.Code: Select all
orCode: Select all
Replacing /dev/sr0 with the correct device path as needed to get the drive speed.Code: Select all
orCode: Select all
Replacing /dev/sr0 with the correct device path as needed.Code: Select all
My drive came with a USB-A Y-cable, and I have both of the Y connectors plugged into USB ports on the back of my desktop machine. I could try instead plugging into two separate 2A USB power blocks. Would that be better?skyrider wrote: Tue Jun 23, 2026 4:32 pm Thank you, Sayaka, for this guide. It may be very useful.
I think this won't help. Tell us exactly what kind of enclosure it is. Is it a drive in a Verbatim enclosure, or something else.
Also write what motherboard model is in the computer.
Click here
Click here
The enclusure is a Verbatim 43890. The computer is a Dell Inspiron 3891 with a proprietary Micro-ATX motherboard built on the Intel B560 chipset.skyrider wrote: Tue Jun 23, 2026 6:39 pm I think this won't help. Tell us exactly what kind of enclosure it is. Is it a drive in a Verbatim enclosure, or something else.
Btw you probably don't need to bother getting 1.17.7 or older. The issue with newer versions affect only non-LibreDrive (perhaps even just some). AFAIK it's nothing "dangerous" anyway.
Wrong. The main issue with newer Linux versions of MakeMKV (newer than 1.17.7) is that they have a broken universal firmware tool. This also seems to be why MakeMKV freezes with some non-LibreDrive drives, it's trying to do a firmware dump and it's unable to do so. If you copy & paste the Windows firmware dump for your drive into your MakeMKV config folder on your Linux OS, MakeMKV is likely to proceed as it should. Same thing if you flash LibreDrive firmware to your drive with your Linux OS with, say, 1.17.6 and then go back to 1.18.4Btw you probably don't need to bother getting 1.17.7 or older. The issue with newer versions affect only non-LibreDrive (perhaps even just some). AFAIK it's nothing "dangerous" anyway.
The guide I posted will likely *not* work with any version newer than 1.17.7, because attempting to run the firmware tool will likely cause the program to freeze. I ran some tests with newer versions on my machine and it's exactly what happened : the program froze instantly. I had to force quit the program with CTRL + C.
EDIT : If anyone wants to test it, it should be relatively simple. Just enter the following command with 1.18.4, for example :
makemkvcon f -n -t mtk19xx helpRe: UHD ripping works, but extremely slow
Ah right. Now that I recall I once wanted to dump whatever can be dumped from my Pioneer drive, and IIRC it did stall.
I suppose the firmware dumping / speed setting bits are not the same bits that are involved in "activating" LibreDrive / disabling bus encryption then...
P.S. It's really weird that mike seems to have no idea what have resulted in the issue. Even weirder is that I saw someone claimed that it doesn't exist on ARM platforms / builds...
If it's the Verbatim 43890, you should have a dedicated external power adapter included. Have you tried connecting the power adapter to this drive? If not, connect the power adapter to the enclosure and plug the single USB 3.0 connector (the thicker one) into the computer. How does the drive behave then?seplant wrote: Tue Jun 23, 2026 7:01 pmThe enclusure is a Verbatim 43890. The computer is a Dell Inspiron 3891 with a proprietary Micro-ATX motherboard built on the Intel B560 chipset.skyrider wrote: Tue Jun 23, 2026 6:39 pm I think this won't help. Tell us exactly what kind of enclosure it is. Is it a drive in a Verbatim enclosure, or something else.
Regarding the Y‑USB cable, if you are using a desktop PC, plug both ends of the USB Y cable directly into the USB ports on the back of the computer (to the mainboard) rather than the front panel.
If that doesn't help, try checking the drive on another computer or laptop. If you have access to a USB hub with its own power supply, check whether the drive works properly when connected through the powered hub.
Click here
Click here
Thanks for all the advice. I read where my computer has a USB 3.2 Gen 1 port, so I plugged the main power USB connector for my drive into that, and now it's ripping very quickly!
