drknight71
Post
by drknight71 » Tue Jun 09, 2026 7:51 pm
nicholfd wrote: Sun Jun 07, 2026 1:03 pm
drknight71 wrote: Sun Jun 07, 2026 2:18 am
Hi guys,
Just bought an OWC Mercury Pro and according to this it needs modification to work? Also is it compatible with a Pioneer 211M 1.54 firmware? Thanks
The OWC chassis doesn't care about the drive Mfg or firmware.
The "modification" is mechanical. When you put the longer (Pioneer) drive in the chassis, you'll see that the drive can't be inserted far enough for the chassis/drive screw holes to line up properly. You merely need to bend the OWC chassis sheetmetal mounting tabs slightly toward the front of the chassis to get the screw holes to line up.
Thanks,
Frank
Thats good to know but as I understand based on previous use of others is that the 1.54 firmware has an issue with most SATA adapters and only works effectively if connected via a Sata cable or using a Benfei adapter. So last night i took apart an old Venus DS enclosure that was usb 2.0 spec and modded it by sneaking that benfei adapter in there with a sata extension cable such that using the power delivery system of the enclosure instead there by upgrading the chassis to usb 3.0 standard. Will use the OWC with an old LG drive instead.
nicholfd
Post
by nicholfd » Tue Jun 09, 2026 10:13 pm
drknight71 wrote: Tue Jun 09, 2026 7:51 pm
Hi guys,
Thanks,
Frank
You misunderstand the issue with SATA adapters. It has nothing to do with drive firmware. It's the crappy SATA adapters that do not fully implement the SATA standard. The OWC enclosure has always had very well working SATA -> USB internals.
USB 3.x vs. USB 2.x gains you nothing for ripping discs - ripping speeds are limited by drives/firmware. 4x-6x is the max you will get, and USB 2.x is faster than that.
nicholfd
Post
by nicholfd » Tue Jun 09, 2026 10:14 pm
Kusakun wrote: Tue Jun 09, 2026 2:28 pm
Hi guys im new in here. i was wondering regarding the LG WH14NS40 i have since 2012 and its been almost unused (about 20 bluray disc played and 10 recorded)
I wanted to know if i can use it or not for UHD backups. I found this in here but wanted to know how to flash it in this case
LG WH14NS40, UHD Friendly Internal 5.25 sata | Rip speed 8x BD 66 ~45 mins BD 100 ~1 hour if flashed properly other wise 6x rips speed and slower then BU40N
Thanks a lot!
Copy/paste the MakeMKV drive info.
Post
by MartyMcNuts » Wed Jun 10, 2026 1:11 am
Thanks a lot!
I'd say not as only models manufactured from 2016 and have the MT1959 drive platform are UHD capable. Anyway, copy and paste the MakeMKV drive info and libredrive info text sections for confirmation.
For UHD enabled drives (AU/NZ/SG + Others) & DIY Single Drive Flasher (WW):
https://uhdenableddrives.com
NoMoreSorry
Post
by NoMoreSorry » Mon Jun 15, 2026 6:14 pm
Hello, I am new here, wondering if my drive can be flashed to UHD. Any help would be greatly appreciated!
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: DDDL291769WL
Firmware date: 2023-04-20
Drive platform: RS8511
Firmware version: E102/ID26
Post
by Billycar11 » Mon Jun 15, 2026 6:39 pm
NoMoreSorry wrote: Mon Jun 15, 2026 6:14 pm
Manufacturer: ASUS
Revision: E102
sure email me that info and
all others email me no need to post your info here publicly just reach out to me directly
see below for email
Crotalus
Post
by Crotalus » Tue Jun 23, 2026 3:10 am
I bought a BP50NB40 NB50 based on this guide and it doesn't look like it'll work, SDFtool Flasher gives me an error that it doesn't have the correct platform (MT1959).
Are there recent recommendations for drives that are available in the US and known to work? I took a couple weeks to order this one from overseas because it was on the list, so I'm wary of picking another off the list and giving it a shot.
nicholfd
Post
by nicholfd » Tue Jun 23, 2026 1:58 pm
Crotalus wrote: Tue Jun 23, 2026 3:10 am
Hello!
Myself & others have pre-flashed drives on-hand & available for purchase in the US. My "For sale" threads are linked in my signature. If you have any questions, you can also e-mail me directly at the e-mail address in my signature.
Thanks,
Frank
mande2021
Post
by mande2021 » Tue Jun 23, 2026 3:54 pm
I'm sure this has been asked before, but when I try to open sdf.bin on my Mac I'm getting the "unsupported format" message. Is there a way around this?
Post
by dcoke22 » Tue Jun 23, 2026 8:08 pm
mande2021 wrote: Tue Jun 23, 2026 3:54 pm
Are you double-clicking on sdf.bin? What are you trying to accomplish? That isn't an executable file.
tomty89
Post
by tomty89 » Tue Jun 23, 2026 8:29 pm
Does MakeMKV state that it is MT1939 though? Or is there no LibreDrive information shown at all?
Note that bad USB adapter / enclosure can "hide" things about the drive.
