1.74 fails to find episodes on As Time Goes By S3 Disc 2
mmlloorrdd
#1 Post by mmlloorrdd » Sat Apr 21, 2012 6:19 pm
(Linux) v1.74 has worked wonderfully for the other ten or so discs of this program,
but fails to find any of the episodes on series 3 disc 2 (.ISO image).
Log file below. Also attaching the DVD structure (the .IFO and .BUP files) as tar.gz.
Debug log started at Sat Apr 21 18:03:49 2012 , written by MakeMKV v1.7.4 linux(x64-release)
001005:0000 MakeMKV v1.7.4 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /root/MakeMKV_log.txt
Title skip vts=1 pgcn=1 hash=D96B338F3C425815
Title skip vts=1 pgcn=2 hash=6EDCFA6856CF83E0
Title skip vts=1 pgcn=3 hash=5E975433532F27DA
Title skip vts=1 pgcn=4 hash=2930A1A8BD258E31
003028:0000 Title #4 was added (2 cell(s), 0:05:38)
003025:0000 Title #5 has length of 31 seconds which is less than minimum title length of 60 seconds and was therefore skipped
003028:0000 Title #6 was added (1 cell(s), 0:01:03)
003025:0000 Title #7 has length of 44 seconds which is less than minimum title length of 60 seconds and was therefore skipped
003028:0000 Title #8 was added (1 cell(s), 0:01:24)
003025:0000 Title #9 has length of 34 seconds which is less than minimum title length of 60 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at b3Dmw7LAas4etEV5jmZdE92w:0
005014:0000 Saving 3 titles into directory /root/Videos/ATGB3_2
AV sync issues in /root/Videos/ATGB3_2/title00.mkv
AV sync in 1 at 0:00:00 (2.4ms) : encountered overlapping frame, audio skew is -2.4ms
005005:0080 3 titles saved
005036:0104 Copy complete. 3 titles saved.
Application exited at Sat Apr 21 18:04:25 2012
ATGB3_2_info.tgz
.IFO and .BUP files, plus copy of log file.
(150.75 KiB) Downloaded 469 times
mmlloorrdd
Re: 1.74 fails to find episodes on As Time Goes By S3 Disc 2
#2 Post by mmlloorrdd » Sat Apr 21, 2012 6:38 pm
Mmm.. possibly a corrupted rip. I'll redo it and try again.
Ignore this for now thanks.
mmlloorrdd
#3 Post by mmlloorrdd » Sat Apr 21, 2012 7:48 pm
Yup. Corrupted file.
Pardon the noise.
