LibreDrive for Pioneer drives
zittrig
#2026 Post by zittrig » Tue Jun 23, 2026 11:34 am
coteedml wrote: Tue Jun 23, 2026 11:28 am Hello!
I have a Pioneer BDR 212BK I am hopeful that Libredrive can be enabled. I really just want to be able to process Bluray disks, no real need to process UHD but I'll partner with Billy on that is needed.
I'm running Makemkv V1.18.4 and I see that LibreDrive shows possible, not yet enabled. Any assistance would be greatly appreciated.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-212BK
Revision: 1.04
Serial number: DCDL048XXXXX
Firmware date: 2022-12-20
Highest AACS version: 82
Firmware version: ID81
Sorry, firmware is past November 2022, no flashing possible.
#2027 Post by Billycar11 » Tue Jun 23, 2026 11:36 am
zittrig wrote: Tue Jun 23, 2026 11:34 am
OS device name: E:
Revision: 1.04
i can flash it
zittrig
#2028 Post by zittrig » Tue Jun 23, 2026 12:50 pm
Billycar11 wrote: Tue Jun 23, 2026 11:36 am
OS device name: E:
Revision: 1.04
i can flash it
Aah, sorry, I've forgot :!:
telepho
#2029 Post by telepho » Sat Jun 27, 2026 3:31 pm
I have a Pioneer BDR-X12 with firmware 1.03 (ID56 / RS9000 platform) on a Mac. I am facing immediate disc ejection with 4K UHD discs.
I have a Windows laptop ready to flash the drive.
Could you please provide the correct customized clean firmware pack for my drive?
Thank you very much for your help!
Telepho
#2030 Post by Billycar11 » Sat Jun 27, 2026 8:06 pm
telepho wrote: Sat Jun 27, 2026 3:31 pm Hello,
Telepho
Email me your makemkv drive info section see below for email
Viola
#2031 Post by Viola » Sun Jun 28, 2026 12:44 am
Hi, I have a Pioneer BDR-XS07TUHD with firmware 1.03. seems work normally, but with few specific blurays seems have problems. I have a BDR-XS07TS fw 1.01 and seems work well. Do you know if there are problems with that firmware on XS07TUHD?
cyberschlumpf
#2032 Post by cyberschlumpf » Sun Jun 28, 2026 10:01 am
cyberschlumpf wrote: Mon Jun 22, 2026 8:18 pm
Billycar11 wrote: Mon Jun 22, 2026 7:44 pm
cyberschlumpf wrote: Mon Jun 22, 2026 7:23 pm
Sorry, how do think the drive should be connected? USB C directly to the host computer and USB to a powered USB hub? But the hub should not be connected to the host? I wonder because basically data was sent both though USB A and USB C: I tried connecting them alternatively and with both connections the drive was detected by the host. Would that cause issues if both plugs deliver data?
For what it's worth: This is the drive and a picture of the connecting cable: https://de.aliexpress.com/item/1005008728799098.html
Either direct to PC or to a powered USB hub
The hub must connect to host...
Only 1 cable is being used for data not both
Uff, just realized that at the back of the device there is an additonal USB C port labeled DC, 5V. I didn´t notice that one at all yet... Used a 3A powered USB C hub to power the drive via that port and connected with the fixed USB cable to the host... Unfortunately, the errors persist... I still get all kind of USB related errors :-(
[385635.992159] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 a9 05 18 00 00 3c 00 00 00
[385635.992160] critical target error, dev sr0, sector 44307552 op 0x0:(READ) flags 0x4800 phys_seg 15 prio class 2
[385636.205046] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[385636.205051] sr 0:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[385636.205053] sr 0:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[385636.205056] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 a9 0c 20 00 00 3c 00 00 00
[385636.205057] critical target error, dev sr0, sector 44314752 op 0x0:(READ) flags 0x4800 phys_seg 14 prio class 2
[385637.071831] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[385637.071836] sr 0:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[385637.071839] sr 0:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[385637.071843] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 a9 31 58 00 00 3c 00 00 00
[385637.071844] critical target error, dev sr0, sector 44352864 op 0x0:(READ) flags 0x4800 phys_seg 14 prio class 2
[385638.963739] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[385638.963744] sr 0:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[385638.963746] sr 0:0:0:0: [sr0] tag#0 Add. Sense: Synchronous data transfer error
[385638.963749] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 a9 8f d8 00 00 3c 00 00 00
[385638.963750] critical target error, dev sr0, sector 44449632 op 0x0:(READ) flags 0x4800 phys_seg 8 prio class 2
[385674.242255] usb 1-3.1: reset high-speed USB device number 22 using xhci_hcd
[385704.455476] usb 1-3.1: reset high-speed USB device number 22 using xhci_hcd
[385721.328486] usb 1-3.1: reset high-speed USB device number 22 using xhci_hcd
[385721.469443] usb 1-3.1: reset high-speed USB device number 22 using xhci_hcd
[385732.081055] usb 1-3.1: reset high-speed USB device number 22 using xhci_hcd
[385732.160299] sr 0:0:0:0: Device offlined - not ready after error recovery
[385732.160310] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK cmd_age=88s
[385732.160313] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 aa a1 20 00 00 3c 00 00 00
[385732.160314] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x4800 phys_seg 30 prio class 2
[385732.160333] sr 0:0:0:0: rejecting I/O to offline device
[385732.160336] I/O error, dev sr0, sector 44729712 op 0x0:(READ) flags 0x4800 phys_seg 30 prio class 2
[385732.160381] I/O error, dev sr0, sector 44729952 op 0x0:(READ) flags 0x4800 phys_seg 30 prio class 2
[385732.160387] I/O error, dev sr0, sector 44730192 op 0x0:(READ) flags 0x800 phys_seg 6 prio class 2
[385732.161132] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[385732.161236] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[385732.161401] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[385732.161454] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[385732.161487] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[385732.161730] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
Is there a firmware 1.02 for that drive? I've seen in other posts there seems to be one, but I couldn´t find anything for that model on the pioneer webpage?
Turned out all the read errors and USB bus resets/drive going to sleep/freezing/... turned out to be sourced in the drive itself I bought from Ali. Maybe the drive is already 10+ years, when the scavenge them from returned notebooks or whatever I don't know. I returned the drive and bought an ASUS SBW-06D5H-U instead that I flashed with the BU40N 1.03MK firmware to make it a Libredrive. All discs were perfectly ripped/read and none of the errors of the old drive popped up. The drive was approx 2x the price of the Ali Pioneer drive but: buy cheap, buy twice...
#2033 Post by Billycar11 » Sun Jun 28, 2026 12:43 pm
Viola wrote: Sun Jun 28, 2026 12:44 am Hi, I have a Pioneer BDR-XS07TUHD with firmware 1.03. seems work normally, but with few specific blurays seems have problems. I have a BDR-XS07TS fw 1.01 and seems work well. Do you know if there are problems with that firmware on XS07TUHD?
no issues with your fw on either drive
if you want the ts drive to do UHD email me see below for that
Runaround5500
#2034 Post by Runaround5500 » Sun Jul 05, 2026 10:11 pm
I have a pioneer drive that I'm hoping can be LibreDrive enabled. Can anybody help me understand what I need to do for this?
OS device name: /dev/sr0
Product: BD-RW BDR-212U
Revision: 1.04
Serial number: CJDLXXXXXXXX
Highest AACS version: 76
Drive platform: Pioneer RS8F01
Firmware version: ID83
#2035 Post by Billycar11 » Sun Jul 05, 2026 10:15 pm
Runaround5500 wrote: Sun Jul 05, 2026 10:11 pm Hello,
Revision: 1.04
Strange as this sounds just run the official pioneer updater
#2036 Post by Coopervid » Mon Jul 06, 2026 7:57 pm
Revision: 1.04
Most likely 1.04 is not yet supported by Mike. Update to 1.05 with the official flasher from Pioneer and try again.
tomty89
#2037 Post by tomty89 » Tue Jul 07, 2026 11:23 am
As per viewtopic.php?t=18856 only 1.01 and 1.02 of the ID83 variant is supported. So you'll either need service from Billy (for crossflashing into the ID58 variant), or send the firmware dump to mike and see. (No idea what kind of dump he needs exactly.)
P.S. Probably doesn't hurt to update just in case the list isn't up-do-date, but may want to consult with Billy first just in case.
W4v3sBy3
#2038 Post by W4v3sBy3 » Sat Jul 11, 2026 12:55 pm
Confirmed SDF.bin is not out of date. Was able to backup Community (TV series) but tried several 4K discs and they read on a 6x LG I've flashed, but I just got a faster Pioneer (Newegg) and 4K discs don't read:
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: DGDL056283WL
Firmware date: 2022-03-16
Bus encryption flags: 13
Highest AACS version: 65
Drive platform: RS8F00
Firmware version: 1.02/ID61
#2039 Post by Billycar11 » Sat Jul 11, 2026 1:22 pm
W4v3sBy3 wrote: Sat Jul 11, 2026 12:55 pm Hello,
Revision: 1.02
your drive is not a 4K drive but i can turn it into one
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
Miromoon
#2040 Post by Miromoon » Sat Jul 18, 2026 3:35 am
I would like to know if my drive can be cross-flashed for UHD Blu-ray reading and which firmware is recommended.
Drive Information:
- Drive: ASUS SBW-06D5H-U
- Platform: RS8511
- Firmware name: PIONEER BDR-US03
- Firmware version: E101/ID26
- Firmware type: Original (unpatched)
- Firmware date: 2018-08-22
LibreDrive Information:
- Status: Enabled
- DVD all regions: Yes
- BD raw data read: Yes
- BD raw metadata read: Yes
- Unrestricted read speed: Yes
My UHD Blu-ray discs are currently not recognized, while regular Blu-ray discs work.
Could you please check whether this specific drive is compatible with the available UHD firmware and advise which firmware/tool should be used?
Thank you very much for your help.
