Leprechaun UHD Replacement Disc
maczrool
Post by maczrool »
Has anyone received their replacement Leprechaun disc and successfully ripped it? I get hash check errors near the beginning but there are no visible scratches and I have already cleaned the disc. It completes the rip after 5 hours or so with errors that show as glitches in the image on my ripping PC and that crash Plex when trying to play back. The drive (BD-RE WH16NS40) rips other discs without issue and my Panasonic DP-UB820 seems to play the disc fine.
maczrool
Re: Leprechaun UHD Replacement Disc
Post by maczrool »
I still can't rip the disc without error and it is the disc because I have since tried other discs that work without issue. It might be a a red herring, but I ran the ripped file through MKVToolNix and although playing it on my PC through Windows Media Player still produces glitches, it now plays fine on Plex and without glitches.
Trancers77
Post by Trancers77 »
I am having the same issue and using three different UHD drives. I attempt to make a backup and that failed as well.
phytonic13
Post by phytonic13 »
My replacement disc took 4 hours to complete. Never seen anything close to that before. It did finish successfully though.
2wicky
Post by 2wicky »
Same here but mine took 7 hrs. Never had that happen but it did finish.
jacobmendez
Post by jacobmendez »
My current rip is stuck at an output size of 484.2M and telling me it has 86 hours remaining. What is wrong with this disc?
2wicky
Post by 2wicky »
That's where mine hung up. Just wait it out. At one point mine said 115hrs.
waiting is a bad idea puts a lot of wear on your drive if its not done or close to being done in 2 hours forget it clean the disc if the same happens replace it
it not worth killing a out of production bluray drive over a $20 disc
