LibreDrive for Pioneer drives
zittrig
#2011 Post by zittrig » Sun Jun 21, 2026 3:55 pm
nicholfd wrote: Sun Jun 21, 2026 3:15 pm
zittrig wrote: Sun Jun 21, 2026 5:08 am Pioneer Issue: ASUS SBC-06D2X-U with platform RS8950 and fw 1.10 is not supported.
Post the MakeMKV drive info. If it's newer firmware, did you et a firmware dump & send it in?
Thanks, no, I don't sent the dump yet. Where do I send? EDIT: Sent to svq@makemkv.com.
Laufwerksinformation
OS-Gerätename: F:
Produzent: ASUS
Produkt: SBC-06D2X-U
Revision: 1.10
Serienummer: XXXXXXX
Firmware-Datum: 2017-04-18
Highest AACS version: 82
Drive platform: Pioneer RS8590
Firmware version: ID22
Keine Disk eingelegt
#2012 Post by Coopervid » Mon Jun 22, 2026 9:05 am
zittrig wrote: Sun Jun 21, 2026 3:55 pm
OS-Gerätename: F:
Produzent: ASUS
Revision: 1.10
You could try to flash it to RS8591 1.10. I think this firmware is supported. Let me know.
tomty89
#2013 Post by tomty89 » Mon Jun 22, 2026 1:25 pm
Coopervid wrote: Mon Jun 22, 2026 9:05 am You could try to flash it to RS8591 1.10. I think this firmware is supported. Let me know.
I feel like the key is whether BDRFlash has whitelisted RS8590 -> RS8591 (and whether the firmware and kernel are available anywhere).
#2014 Post by Coopervid » Mon Jun 22, 2026 1:50 pm
tomty89 wrote: Mon Jun 22, 2026 1:25 pm
Available here and pretty sure it will work.
cyberschlumpf
#2015 Post by cyberschlumpf » Mon Jun 22, 2026 4:06 pm
I'm having some issues with a BR burner I bought on Aliexpress and which turned out much to my joy to be a Libredrive Pioneer BD-RW BDR-TD05D 1.00
Problem is:
I was able to rip so far 4 of the 8 BR successfully. It happened one or twice that the initial read of the TOC lead to missing chapters or episodes, but when I ejected and reinserted the disc it could be read. Now starting with the 5th disc, I cannot read/rip any BR successfully any longer... Sometimes the various episodes (6 per BR) are not properly detected or the rip just dies in the middle. The kernel log shows all kind of errors (see bottom of post) and also the UI throws all kind of unreadable errors.
Did I get a broken drive? Can anything be done about this? It does not look like a disc problem, does it?
I see the firmware is V1.00 - is there an update maybe? Thing is I cannot find the model BDR-TD05D on the Pioneer site... Is it fake...?
Using the Linux version here, but the same behavior was observed on Windows with the latest beta.
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-TD05D
Revision: 1.00
Serial number: LKDL123xxxxx
Firmware date: 2012-07-13
Highest AACS version: 68
Drive platform: RS8211
Firmware name: PIONEER BDR-TD05
Firmware version: 1.00/ID84
Disc Information
Label: xxxxxxxxxxxxxx
Timestamp: 2023-08-17 16:01:09
Protection: AACS v68
Data capacity: 40.59 Gb
Disc type: BD-ROM
Number of layers: 2
[369921.843270] usb-storage 1-3.1:1.0: USB Mass Storage device detected
[369921.843602] scsi host2: usb-storage 1-3.1:1.0
[369922.433533] scsi 0:0:0:0: Direct-Access Mass Storage Device 1.00 PQ: 0 ANSI: 0 CCS
[369922.433920] sd 0:0:0:0: Attached scsi generic sg0 type 0
[369922.712479] sd 0:0:0:0: [sda] Media removed, stopped polling
[369922.712806] sd 0:0:0:0: [sda] Attached SCSI removable disk
[369922.882591] scsi 2:0:0:0: CD-ROM PIONEER BD-RW BDR-TD05D 1.00 PQ: 0 ANSI: 0
[369922.891738] sr 2:0:0:0: Power-on or device reset occurred
[369922.909747] sr 2:0:0:0: [sr0] scsi3-mmc drive: 62x/62x writer dvd-ram cd/rw xa/form2 cdda tray
[369922.919554] sr 2:0:0:0: Attached scsi CD-ROM sr0
[369922.919701] sr 2:0:0:0: Attached scsi generic sg2 type 5
[369931.164379] UDF-fs: INFO Mounting volume 'xxxxxxxxxxxxxxxxxxxxxxxx', timestamp 2023/08/17 14:01 (1000)
[370008.954215] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370008.954220] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370008.954223] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370008.954225] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 10 54 b8 00 00 3c 00 00 00
[370008.954226] blk_print_req_error: 67 callbacks suppressed
[370008.954227] critical target error, dev sr0, sector 71389920 op 0x0:(READ) flags 0x4800 phys_seg 9 prio class 2
[370009.467481] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370009.467485] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370009.467488] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370009.467490] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 10 63 40 00 00 3c 00 00 00
[370009.467491] critical target error, dev sr0, sector 71404800 op 0x0:(READ) flags 0x4800 phys_seg 29 prio class 2
[370009.920130] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370009.920136] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370009.920140] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370009.920143] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 10 70 c0 00 00 3c 00 00 00
[370009.920145] critical target error, dev sr0, sector 71418624 op 0x0:(READ) flags 0x4800 phys_seg 9 prio class 2
[370010.015416] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370010.015420] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370010.015423] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370010.015425] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 10 73 78 00 00 3c 00 00 00
[370010.015426] critical target error, dev sr0, sector 71421408 op 0x0:(READ) flags 0x4800 phys_seg 8 prio class 2
[370010.244308] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370010.244313] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370010.244315] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370010.244318] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 10 7a bc 00 00 3c 00 00 00
[370010.244319] critical target error, dev sr0, sector 71428848 op 0x0:(READ) flags 0x4800 phys_seg 8 prio class 2
[370031.225527] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370031.225532] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370031.225534] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370031.225537] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 13 52 00 00 00 3c 00 00 00
[370031.225538] critical target error, dev sr0, sector 72173568 op 0x0:(READ) flags 0x4800 phys_seg 4 prio class 2
[370041.828588] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370041.828593] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370041.828595] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370041.828597] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 14 bd c0 00 00 3c 00 00 00
[370041.828598] critical target error, dev sr0, sector 72546048 op 0x0:(READ) flags 0x4800 phys_seg 15 prio class 2
[370061.889225] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370061.889229] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370061.889232] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370061.889234] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 17 66 c0 00 00 3c 00 00 00
[370061.889235] critical target error, dev sr0, sector 73243392 op 0x0:(READ) flags 0x4800 phys_seg 4 prio class 2
[370077.002501] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370077.002505] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370077.002508] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370077.002510] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 19 61 3c 00 00 3c 00 00 00
[370077.002511] critical target error, dev sr0, sector 73762032 op 0x0:(READ) flags 0x4800 phys_seg 4 prio class 2
[370098.408360] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370098.408365] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370098.408368] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370098.408370] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 1c 24 40 00 00 3c 00 00 00
[370098.408371] critical target error, dev sr0, sector 74486016 op 0x0:(READ) flags 0x4800 phys_seg 16 prio class 2
[370099.921108] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370099.921113] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370099.921114] sr 2:0:0:0: [sr0] tag#0 Add. Sense: Synchronous data transfer error
[370099.921116] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 1c 55 c0 00 00 3c 00 00 00
[370099.921117] critical target error, dev sr0, sector 74536704 op 0x0:(READ) flags 0x4800 phys_seg 8 prio class 2
[370102.747825] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370102.747830] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370102.747832] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370102.747834] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 1c b2 00 00 00 3c 00 00 00
[370102.747835] critical target error, dev sr0, sector 74631168 op 0x0:(READ) flags 0x4800 phys_seg 5 prio class 2
[370105.616256] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370105.616260] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370105.616262] sr 2:0:0:0: [sr0] tag#0 Add. Sense: Synchronous data transfer error
[370105.616265] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 1d 0f c0 00 00 3c 00 00 00
[370105.616266] critical target error, dev sr0, sector 74727168 op 0x0:(READ) flags 0x4800 phys_seg 5 prio class 2
[370121.623069] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370121.623073] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370121.623075] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370121.623077] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 1f 15 b8 00 00 3c 00 00 00
[370121.623078] critical target error, dev sr0, sector 75257568 op 0x0:(READ) flags 0x4800 phys_seg 4 prio class 2
[370131.619120] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370131.619125] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370131.619126] sr 2:0:0:0: [sr0] tag#0 Add. Sense: Synchronous data transfer error
[370131.619128] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 20 56 34 00 00 0c 00 00 00
[372880.040561] sr 1:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[372880.040563] sr 1:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 17 41 7c 00 00 3c 00 00 00
[372880.040565] critical target error, dev sr0, sector 73205232 op 0x0:(READ) flags 0x4800 phys_seg 29 prio class 2
[372948.495658] usb 1-3.1: reset high-speed USB device number 102 using xhci_hcd
[372978.708644] usb 1-3.1: reset high-speed USB device number 102 using xhci_hcd
[372995.580925] usb 1-3.1: reset high-speed USB device number 102 using xhci_hcd
[372995.723943] usb 1-3.1: reset high-speed USB device number 102 using xhci_hcd
[373006.332845] usb 1-3.1: reset high-speed USB device number 102 using xhci_hcd
[373006.410872] sr 1:0:0:0: Device offlined - not ready after error recovery
[373006.410904] sr 1:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK cmd_age=88s
[373006.410907] sr 1:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 1c 33 40 00 00 3c 00 00 00
[373006.410908] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x4800 phys_seg 30 prio class 2
[373006.410952] sr 1:0:0:0: rejecting I/O to offline device
[373006.410954] I/O error, dev sr0, sector 74501616 op 0x0:(READ) flags 0x4800 phys_seg 26 prio class 2
[373006.411001] I/O error, dev sr0, sector 74501856 op 0x0:(READ) flags 0x4800 phys_seg 27 prio class 2
[373006.411008] I/O error, dev sr0, sector 74502096 op 0x0:(READ) flags 0x800 phys_seg 6 prio class 2
[373006.411399] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[373006.411569] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[373006.411600] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[373006.411622] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[373006.411694] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[373006.411919] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
UI says:
Drive locks up, does not eject disc until I physically disconnect the USB cable and HW reset it
Last edited by cyberschlumpf on Mon Jun 22, 2026 4:42 pm, edited 2 times in total.
zittrig
#2016 Post by zittrig » Mon Jun 22, 2026 4:08 pm
Thanks for this idea. Where can I find the 1.10 for the RS8591? :)
#2017 Post by Coopervid » Mon Jun 22, 2026 5:11 pm
zittrig wrote: Mon Jun 22, 2026 4:08 pm Thanks for this idea. Where can I find the 1.10 for the RS8591? :)
In your PM.
cyberschlumpf
#2018 Post by cyberschlumpf » Mon Jun 22, 2026 5:25 pm
cyberschlumpf wrote: Mon Jun 22, 2026 4:06 pm I'm having some issues with a BR burner I bought on Aliexpress and which turned out much to my joy to be a Libredrive Pioneer BD-RW BDR-TD05D 1.00
I've just read that power supply might be one of the reasons it could fail?
The enclose has a fixed cable on the drive side which goes into a classic USB A type plug into the host. In that USB plug you also have a cable outgoing (just 5cm long!) of type USB C, so it's way to short to plug both cables in at once. I've tried just plugging the USB C cable in and had all kind of errors just reading the TOC. (Internal error in MakeMKV etc.)... I am not supposed to put that into a USB wall charger to something, am I?
I also read it's not advisable to use a powered USB hub but I don´t see how I would then be able to give more power to the device?
Last edited by cyberschlumpf on Mon Jun 22, 2026 5:47 pm, edited 2 times in total.
#2019 Post by Billycar11 » Mon Jun 22, 2026 6:48 pm
cyberschlumpf wrote: Mon Jun 22, 2026 5:25 pm
It is advertised to use a powered USB hub
It Is not advised to use an external USB power adapter without diode in the cable and it can damage your pc
zittrig
#2020 Post by zittrig » Mon Jun 22, 2026 6:55 pm
Coopervid wrote: Mon Jun 22, 2026 5:11 pm
In your PM.
Flash successfull, drive works like a charme as a RS8591. My brother will be happy when he get his drive tomorrow!
Thanks Coopervid :!:
#2021 Post by Coopervid » Mon Jun 22, 2026 6:56 pm
zittrig wrote: Mon Jun 22, 2026 6:55 pm
In your PM.
You are very welcome!
cyberschlumpf
#2022 Post by cyberschlumpf » Mon Jun 22, 2026 7:23 pm
Billycar11 wrote: Mon Jun 22, 2026 6:48 pm
Sorry, how do think the drive should be connected? USB C directly to the host computer and USB to a powered USB hub? But the hub should not be connected to the host? I wonder because basically data was sent both though USB A and USB C: I tried connecting them alternatively and with both connections the drive was detected by the host. Would that cause issues if both plugs deliver data?
For what it's worth: This is the drive and a picture of the connecting cable: https://de.aliexpress.com/item/1005008728799098.html
#2023 Post by Billycar11 » Mon Jun 22, 2026 7:44 pm
cyberschlumpf wrote: Mon Jun 22, 2026 7:23 pm
Either direct to PC or to a powered USB hub
The hub must connect to host...
Only 1 cable is being used for data not both
cyberschlumpf
#2024 Post by cyberschlumpf » Mon Jun 22, 2026 8:18 pm
Billycar11 wrote: Mon Jun 22, 2026 7:44 pm
Uff, just realized that at the back of the device there is an additonal USB C port labeled DC, 5V. I didn´t notice that one at all yet... Used a 3A powered USB C hub to power the drive via that port and connected with the fixed USB cable to the host... Unfortunately, the errors persist... I still get all kind of USB related errors :-(
[385635.992159] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 a9 05 18 00 00 3c 00 00 00
[385635.992160] critical target error, dev sr0, sector 44307552 op 0x0:(READ) flags 0x4800 phys_seg 15 prio class 2
[385636.205046] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[385636.205051] sr 0:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[385636.205053] sr 0:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[385636.205056] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 a9 0c 20 00 00 3c 00 00 00
[385636.205057] critical target error, dev sr0, sector 44314752 op 0x0:(READ) flags 0x4800 phys_seg 14 prio class 2
[385637.071831] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[385637.071836] sr 0:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[385637.071839] sr 0:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[385637.071843] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 a9 31 58 00 00 3c 00 00 00
[385637.071844] critical target error, dev sr0, sector 44352864 op 0x0:(READ) flags 0x4800 phys_seg 14 prio class 2
[385638.963739] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[385638.963744] sr 0:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[385638.963746] sr 0:0:0:0: [sr0] tag#0 Add. Sense: Synchronous data transfer error
[385638.963749] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 a9 8f d8 00 00 3c 00 00 00
[385638.963750] critical target error, dev sr0, sector 44449632 op 0x0:(READ) flags 0x4800 phys_seg 8 prio class 2
[385674.242255] usb 1-3.1: reset high-speed USB device number 22 using xhci_hcd
[385704.455476] usb 1-3.1: reset high-speed USB device number 22 using xhci_hcd
[385721.328486] usb 1-3.1: reset high-speed USB device number 22 using xhci_hcd
[385721.469443] usb 1-3.1: reset high-speed USB device number 22 using xhci_hcd
[385732.081055] usb 1-3.1: reset high-speed USB device number 22 using xhci_hcd
[385732.160299] sr 0:0:0:0: Device offlined - not ready after error recovery
[385732.160310] sr 0:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK cmd_age=88s
[385732.160313] sr 0:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 aa a1 20 00 00 3c 00 00 00
[385732.160314] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x4800 phys_seg 30 prio class 2
[385732.160333] sr 0:0:0:0: rejecting I/O to offline device
[385732.160336] I/O error, dev sr0, sector 44729712 op 0x0:(READ) flags 0x4800 phys_seg 30 prio class 2
[385732.160381] I/O error, dev sr0, sector 44729952 op 0x0:(READ) flags 0x4800 phys_seg 30 prio class 2
[385732.160387] I/O error, dev sr0, sector 44730192 op 0x0:(READ) flags 0x800 phys_seg 6 prio class 2
[385732.161132] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[385732.161236] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[385732.161401] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[385732.161454] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[385732.161487] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[385732.161730] I/O error, dev sr0, sector 44729472 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
Is there a firmware 1.02 for that drive? I've seen in other posts there seems to be one, but I couldn´t find anything for that model on the pioneer webpage?
coteedml
#2025 Post by coteedml » Tue Jun 23, 2026 11:28 am
Hello!
I have a Pioneer BDR 212BK I am hopeful that Libredrive can be enabled. I really just want to be able to process Bluray disks, no real need to process UHD but I'll partner with Billy on that is needed.
I'm running Makemkv V1.18.4 and I see that LibreDrive shows possible, not yet enabled. Any assistance would be greatly appreciated.
OS device name: E:
Product: BD-RW BDR-212BK
Revision: 1.04
Serial number: DCDL048XXXXX
Firmware date: 2022-12-20
Firmware version: ID81
