#2015
Post
by cyberschlumpf » Mon Jun 22, 2026 4:06 pm
I'm having some issues with a BR burner I bought on Aliexpress and which turned out much to my joy to be a Libredrive Pioneer BD-RW BDR-TD05D 1.00
Problem is:
I was able to rip so far 4 of the 8 BR successfully. It happened one or twice that the initial read of the TOC lead to missing chapters or episodes, but when I ejected and reinserted the disc it could be read. Now starting with the 5th disc, I cannot read/rip any BR successfully any longer... Sometimes the various episodes (6 per BR) are not properly detected or the rip just dies in the middle. The kernel log shows all kind of errors (see bottom of post) and also the UI throws all kind of unreadable errors.
Did I get a broken drive? Can anything be done about this? It does not look like a disc problem, does it?
I see the firmware is V1.00 - is there an update maybe? Thing is I cannot find the model BDR-TD05D on the Pioneer site... Is it fake...?
Using the Linux version here, but the same behavior was observed on Windows with the latest beta.
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-TD05D
Revision: 1.00
Serial number: LKDL123xxxxx
Firmware date: 2012-07-13
Highest AACS version: 68
Drive platform: RS8211
Firmware name: PIONEER BDR-TD05
Firmware version: 1.00/ID84
Disc Information
Label: xxxxxxxxxxxxxx
Timestamp: 2023-08-17 16:01:09
Protection: AACS v68
Data capacity: 40.59 Gb
Disc type: BD-ROM
Number of layers: 2
[369921.843270] usb-storage 1-3.1:1.0: USB Mass Storage device detected
[369921.843602] scsi host2: usb-storage 1-3.1:1.0
[369922.433533] scsi 0:0:0:0: Direct-Access Mass Storage Device 1.00 PQ: 0 ANSI: 0 CCS
[369922.433920] sd 0:0:0:0: Attached scsi generic sg0 type 0
[369922.712479] sd 0:0:0:0: [sda] Media removed, stopped polling
[369922.712806] sd 0:0:0:0: [sda] Attached SCSI removable disk
[369922.882591] scsi 2:0:0:0: CD-ROM PIONEER BD-RW BDR-TD05D 1.00 PQ: 0 ANSI: 0
[369922.891738] sr 2:0:0:0: Power-on or device reset occurred
[369922.909747] sr 2:0:0:0: [sr0] scsi3-mmc drive: 62x/62x writer dvd-ram cd/rw xa/form2 cdda tray
[369922.919554] sr 2:0:0:0: Attached scsi CD-ROM sr0
[369922.919701] sr 2:0:0:0: Attached scsi generic sg2 type 5
[369931.164379] UDF-fs: INFO Mounting volume 'xxxxxxxxxxxxxxxxxxxxxxxx', timestamp 2023/08/17 14:01 (1000)
[370008.954215] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370008.954220] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370008.954223] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370008.954225] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 10 54 b8 00 00 3c 00 00 00
[370008.954226] blk_print_req_error: 67 callbacks suppressed
[370008.954227] critical target error, dev sr0, sector 71389920 op 0x0:(READ) flags 0x4800 phys_seg 9 prio class 2
[370009.467481] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370009.467485] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370009.467488] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370009.467490] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 10 63 40 00 00 3c 00 00 00
[370009.467491] critical target error, dev sr0, sector 71404800 op 0x0:(READ) flags 0x4800 phys_seg 29 prio class 2
[370009.920130] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370009.920136] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370009.920140] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370009.920143] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 10 70 c0 00 00 3c 00 00 00
[370009.920145] critical target error, dev sr0, sector 71418624 op 0x0:(READ) flags 0x4800 phys_seg 9 prio class 2
[370010.015416] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370010.015420] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370010.015423] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370010.015425] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 10 73 78 00 00 3c 00 00 00
[370010.015426] critical target error, dev sr0, sector 71421408 op 0x0:(READ) flags 0x4800 phys_seg 8 prio class 2
[370010.244308] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370010.244313] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370010.244315] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370010.244318] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 10 7a bc 00 00 3c 00 00 00
[370010.244319] critical target error, dev sr0, sector 71428848 op 0x0:(READ) flags 0x4800 phys_seg 8 prio class 2
[370031.225527] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370031.225532] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370031.225534] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370031.225537] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 13 52 00 00 00 3c 00 00 00
[370031.225538] critical target error, dev sr0, sector 72173568 op 0x0:(READ) flags 0x4800 phys_seg 4 prio class 2
[370041.828588] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370041.828593] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370041.828595] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370041.828597] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 14 bd c0 00 00 3c 00 00 00
[370041.828598] critical target error, dev sr0, sector 72546048 op 0x0:(READ) flags 0x4800 phys_seg 15 prio class 2
[370061.889225] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370061.889229] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370061.889232] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370061.889234] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 17 66 c0 00 00 3c 00 00 00
[370061.889235] critical target error, dev sr0, sector 73243392 op 0x0:(READ) flags 0x4800 phys_seg 4 prio class 2
[370077.002501] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370077.002505] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370077.002508] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370077.002510] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 19 61 3c 00 00 3c 00 00 00
[370077.002511] critical target error, dev sr0, sector 73762032 op 0x0:(READ) flags 0x4800 phys_seg 4 prio class 2
[370098.408360] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370098.408365] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370098.408368] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370098.408370] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 1c 24 40 00 00 3c 00 00 00
[370098.408371] critical target error, dev sr0, sector 74486016 op 0x0:(READ) flags 0x4800 phys_seg 16 prio class 2
[370099.921108] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370099.921113] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370099.921114] sr 2:0:0:0: [sr0] tag#0 Add. Sense: Synchronous data transfer error
[370099.921116] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 1c 55 c0 00 00 3c 00 00 00
[370099.921117] critical target error, dev sr0, sector 74536704 op 0x0:(READ) flags 0x4800 phys_seg 8 prio class 2
[370102.747825] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370102.747830] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370102.747832] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370102.747834] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 1c b2 00 00 00 3c 00 00 00
[370102.747835] critical target error, dev sr0, sector 74631168 op 0x0:(READ) flags 0x4800 phys_seg 5 prio class 2
[370105.616256] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370105.616260] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370105.616262] sr 2:0:0:0: [sr0] tag#0 Add. Sense: Synchronous data transfer error
[370105.616265] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 1d 0f c0 00 00 3c 00 00 00
[370105.616266] critical target error, dev sr0, sector 74727168 op 0x0:(READ) flags 0x4800 phys_seg 5 prio class 2
[370121.623069] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370121.623073] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370121.623075] sr 2:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[370121.623077] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 1f 15 b8 00 00 3c 00 00 00
[370121.623078] critical target error, dev sr0, sector 75257568 op 0x0:(READ) flags 0x4800 phys_seg 4 prio class 2
[370131.619120] sr 2:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[370131.619125] sr 2:0:0:0: [sr0] tag#0 Sense Key : Hardware Error [current]
[370131.619126] sr 2:0:0:0: [sr0] tag#0 Add. Sense: Synchronous data transfer error
[370131.619128] sr 2:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 20 56 34 00 00 0c 00 00 00
[372880.040561] sr 1:0:0:0: [sr0] tag#0 ASC=0x44 ASCQ=0x7
[372880.040563] sr 1:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 17 41 7c 00 00 3c 00 00 00
[372880.040565] critical target error, dev sr0, sector 73205232 op 0x0:(READ) flags 0x4800 phys_seg 29 prio class 2
[372948.495658] usb 1-3.1: reset high-speed USB device number 102 using xhci_hcd
[372978.708644] usb 1-3.1: reset high-speed USB device number 102 using xhci_hcd
[372995.580925] usb 1-3.1: reset high-speed USB device number 102 using xhci_hcd
[372995.723943] usb 1-3.1: reset high-speed USB device number 102 using xhci_hcd
[373006.332845] usb 1-3.1: reset high-speed USB device number 102 using xhci_hcd
[373006.410872] sr 1:0:0:0: Device offlined - not ready after error recovery
[373006.410904] sr 1:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_ABORT driverbyte=DRIVER_OK cmd_age=88s
[373006.410907] sr 1:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 01 1c 33 40 00 00 3c 00 00 00
[373006.410908] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x4800 phys_seg 30 prio class 2
[373006.410952] sr 1:0:0:0: rejecting I/O to offline device
[373006.410954] I/O error, dev sr0, sector 74501616 op 0x0:(READ) flags 0x4800 phys_seg 26 prio class 2
[373006.411001] I/O error, dev sr0, sector 74501856 op 0x0:(READ) flags 0x4800 phys_seg 27 prio class 2
[373006.411008] I/O error, dev sr0, sector 74502096 op 0x0:(READ) flags 0x800 phys_seg 6 prio class 2
[373006.411399] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[373006.411569] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[373006.411600] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[373006.411622] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[373006.411694] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
[373006.411919] I/O error, dev sr0, sector 74501376 op 0x0:(READ) flags 0x800 phys_seg 2 prio class 2
UI says:
Drive locks up, does not eject disc until I physically disconnect the USB cable and HW reset it
cyberschlumpf on Mon Jun 22, 2026 4:42 pm, edited 2 times in total.
