Disc Won't Play in VLC
koberulz
Re: Disc Won't Play in VLC
#16 Post by koberulz » Mon Jun 22, 2026 5:16 am
If I reinsert the D.E.B.S. disc and play that in Kodi, I get the list of titles etc., but when I select Show Blu-ray Menu it just gets stuck on Please Wait... forever.
Sayaka
#17 Post by Sayaka » Mon Jun 22, 2026 10:01 am
Understood. Please give me a few days to investigate this issue (assuming nobody else manages to solve the problem beforehand), it shouldn't take more than 5 or 6 days, hopefully. And apologies for making you wait.
koberulz
#18 Post by koberulz » Mon Jun 22, 2026 10:39 am
I updated Kodi, which now has a completely different interface, and it's just an infinite spinning wheel rather than a Please Wait... message.
Sayaka
#19 Post by Sayaka » Mon Jun 22, 2026 11:11 am
That's a classic error when a Blu-ray menu is not supported (or at least not with a specific Java version), which is why I'm going to need time to investigate this. Once I have received this particular Blu-ray, maybe I can find a way to make Java work with it by switching Java versions until it works or something.
Just to be clear, the Blu-ray menus *do* work with other Blu-ray discs, yes ? Just to make sure the problem you're having is not due to some obscure Java configuration problem.
koberulz
#20 Post by koberulz » Mon Jun 22, 2026 12:22 pm
Yeah, I've never had any issue with any other disc, and other discs have continued to work fine once I got the environment variable thing sorted out.
Sayaka
#21 Post by Sayaka » Mon Jun 22, 2026 12:31 pm
Thank you for clarifying. I will probably receive D.E.B.S. on Friday or Saturday at the latest. Hopefully I can figure out what's causing this.
