ASUS SBW-06D2X-U
RmbWantsUhd
Re: ASUS SBW-06D2X-U
Hi can anybody help me unlock UHD on this device? Is it possible?
OS device name: *:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: ************
Firmware date: 2017-04-18
Drive platform: RS8511
Firmware version: 1.10/ID22
Thank you
OS device name: *:
Manufacturer: ASUS
Revision: 1.10
Thank you
PM sent.RmbWantsUhd wrote: Fri Feb 27, 2026 9:27 pm Hi can anybody help me unlock UHD on this device? Is it possible?
OS device name: *:
Manufacturer: ASUS
Revision: 1.10
Thank you
rsmrules05
Hi can someone help me get my disk drive to be able to read UHD discs? Since I just created this account I can't initiate a PM yet.
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
Serial number:
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
Serial number:
sure email me that info and all others email me no need to post your info here just reach out to me directlyrsmrules05 wrote: Sun Mar 01, 2026 6:06 pm Hi can someone help me get my disk drive to be able to read UHD discs? Since I just created this account I can't initiate a PM yet.
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
Serial number:
see below for email
I just wanted to thank everyone who posted tips with software and firmware combos in this topic. I was able to make my writer finaly usable. By default it had issues writing BR disks at all, and it was not reading UHD versions of my movies. Now I can not only use it to watch movies on my PC instead of PS5, but also backup files from my computer to larger disks and not just DVDs
lAcidBurnl
Hello, I have this ASUS SBW-06D2X-U that had revision A102 originally (like some others here in this thread) and I managed to flash the drive with "DE_LG_BU40N_1.03_MK.bin". Is it ok if I sit on this version? Saw some people had issues and was recommended to downgrade to 1.0. Problem is that I tried to flash "DE_LG_BU40N_1.00.bin" and flashing goes normally but FW version doesn't change. It keeps me on 1.03.
OS device name: J:
Product: BD-RE BU40N
Revision: 1.03
Serial number: MO9O68F4324
Firmware version: 1.03
OS device name: J:
Revision: 1.03
luanpessoa
Can someone help me unlock mine?
Here are the specs
Informações da Unidade
Nome do dispositivo do SO: D:
Fabricante: ASUS
Produto: SBW-06D2X-U
Revisão: 1.10
Número de série:
Data do Firmware: 2017-04-18
Sinalizações de criptografia bus: 1B
Highest AACS version: 50
Thank you very much!
Here are the specs
Fabricante: ASUS
Revisão: 1.10
Número de série:
PM sent.luanpessoa wrote: Sun Apr 12, 2026 4:50 am Can someone help me unlock mine?
Here are the specs
Fabricante: ASUS
Revisão: 1.10
Número de série:
sure email me that info and all others email me no need to post your info here just reach out to me directlyluanpessoa wrote: Sun Apr 12, 2026 4:50 am Can someone help me unlock mine?
Here are the specs
Fabricante: ASUS
Revisão: 1.10
Número de série:
see below for email
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number: MO8P58C0352
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
This is all the info it gives me. What Firmware should i use?
OS device name: E:
Manufacturer: ASUS
Revision: A102
see guide belowcecil7247 wrote: Wed May 13, 2026 1:41 am Drive Information
OS device name: E:
Manufacturer: ASUS
Revision: A102
or email me or marty for an auto flasher
Hi can anyone help me unlock UHD on this drive? Thank you in advance!
Manufacturer: ASUS
Revision: 1.10
Highest AACS version: 81
sure email me that info and all others email me no need to post your info here just reach out to me directlytimmol wrote: Sun Jun 21, 2026 6:54 pm Hi can anyone help me unlock UHD on this drive? Thank you in advance!
Drive Information Manufacturer: ASUS Product: SBW-06D2X-U Revision: 1.10 Serial number: ************ Firmware date: 2017-04-18 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.10/ID22 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
see below for email
