How to rip an .iso file with MakeMKV
Jules
Hi, everyone!!
I want to make a backup with MakeMKV but I can’t load the .iso file. How can I do this?
Re: How to rip an .iso file with MakeMKV
You can't. You have to rip to folder and then use Imgburn to pick BDMV and CERTIFICATE and write the ISO.
ChromePlanet
You can rip any ISO file with MakeMKV simply by opening the file. I do this routinely after cloning a UHD or BD disc with DVDFab to ISO. If MakeMKV can't open the ISO file or returns an error, it may not have been created correctly. You can't just use DiskUtil to clone an encrypted movie disc to your drive.
theotherguy
FWIW, I'm doing my BluRay discs now, and I just select the folder that contains the 1)BDMV, 2)Certificate, and 3)MakeMKV folders within it. It has usually worked pretty well to create an ISO from that.
Radiocomms237
This subject comes up almost every week lately.
Why we can't just have the option to 'ISO' Blu-ray & UltraHD discs directly from MakeMKV I'll never know. It can already create an image of DVDs, but not BR nor UHD. With LibreDrive, it should be entirely possible.
I just want to have a true image of my discs backed up for posterity. Not decrypted, not just the folders & files that MakeMKV *thinks* I need, but an ISO image of the disc as a whole.
Enable LibreDrive by opening the disc to the title selection screen in MakeMKV.
Use DD to create an ISO from the disc
Obviously you'll have to replace the dev device with the dev device of your UHD drive and the folder path and ISO name but it'll work.
sudo dd if=/dev/cdrom of=/some/folder/iso_name_here.iso
Radiocomms237
You gave me similar instructions for using ImgBurn over in this thread, but I could never make it work.
So I will give this new theory a try, as soon as you let me know what "DD" is???
A command that's used in a bash shell but quite frankly if you couldn't get it to work with imgburn you're not likely to have more success with dd
Sent from my SM-S928U1 using Tapatalk
dd (Unix) can be thought of as a low level copy command in Unix.Radiocomms237 wrote: Mon Apr 22, 2024 1:05 am So I will give this new theory a try, as soon as you let me know what "DD" is???
I think one of the complexities of trying to have MakeMKV create .iso files of blu-rays and UHDs is the UDF filesystem used on optical discs. Most blu-rays use UDF 2.5 (though some use 2.6). I know macOS doesn't have native OS support UDF 2.5. I'm pretty sure Windows doesn't either. And I'd guess most Linux distributions don't have it by default. Consequently, MakeMKV would probably have to add the capability to write UDF 2.5 .iso files to itself as opposed to being able to use the host OS's support for it. That would add a lot of complexity for a relatively small gain.
DVDs generally use UDF 1.02 which I think is relatively well supported across the various OSes.
isamu
It's an old thread, but has there been any progress from Make MKV with this feature? Have they said whether or not ripping UHDs directly to ISO format is on their roadmap?
If not, is IMG Burn still considered the goto app to achieve ripping to ISO? Or is there another app that most people are using these days?
Sayaka
I believe so. I still use it nowadays, even on Linux (with Lutris and WINE, admittedly).If not, is IMG Burn still considered the goto app to achieve ripping to ISO?
isamu
Interesting. I just loaded up DVDFab for the first time in a while, and successfully converted my ripped BDMV folder for Enter the Dragon into an ISO file, mounted it and played it successfully in VLC. It also appears to do 1:1 copies from disc directly to ISO, so I may stick with that and bypass Make MKV altogether.Sayaka wrote: Sun Jun 21, 2026 3:09 pmI believe so. I still use it nowadays, even on Linux (with Lutris and WINE, admittedly).If not, is IMG Burn still considered the goto app to achieve ripping to ISO?
