Hi
I copied four discs last night and two were fine but other two were not. Failry recent UHD releases of Mother's Pride and EPiC Elvis Presley in Concert
They bith said the volume key is uknown for this disc. I even downlaoded the keydb file but still no luck.
Make MKV is set to access the internet, router or isp is not blocking it as it is just these two discs,
Here are the details of this disc and my drive:
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.01
Serial number: BBDL006310WL
Firmware date: 2020-07-21
Highest AACS version: 82
Drive platform: RS8F01
Firmware version: 1.01/ID43
Disc Information
Label: Mothers Pride
Timestamp: 2026-05-08 10:07:31
Protection: AACS2.0/C v82
Data capacity: 47.99 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
And here is the message i get:
Using LibreDrive mode (v02.1 id=1C080B0C438F)
Saved AACS dump file as /home/michael/.MakeMKV/MKB20_v82_Mother's_Pride_9E40.tgz
DEBUG: Code 0 at Kb1&6.>LEQ)p~)v":213132721
DEBUG: Code 0 at Kb1&6.>LEQ)p~)v":213131341
I have already submitted the dumo to the usual email address svq@makemkv.com.
Operating on Linux Mint and never really had any other issues. Already restarted my machine, unplugged the drive, waited overnight etc.
Thoughts?
Movie Key issue
keydb_helper
Re: Movie Key issue
Hey mm8718, if you'd like to see support for your discs added to the public keydb please submit the disc dump files to the keydb thread: Linkmm8718 wrote: Sun Jun 21, 2026 9:50 am Hi
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
mm8718
Re: Movie Key issue
Thankskeydb_helper wrote: Sun Jun 21, 2026 11:35 amHey mm8718, if you'd like to see support for your discs added to the public keydb please submit the disc dump files to the keydb thread: Linkmm8718 wrote: Sun Jun 21, 2026 9:50 am Hi
All done
pokrok86
Re: Movie Key issue
just jumping on this as I'm having same issue with EPiC, summited dump via email too.
