1.18.4 installer flagged by Windows Defender as Bearfoos.B!ml (likely ML false positive)
tahlyn
Post by tahlyn »
Heads up for anyone updating to the new 1.18.4 release.
Windows Defender quarantined Setup_MakeMKV_v1.18.4.exe on my Windows 11 machine today, flagged as Trojan:Win32/Bearfoos.B!ml (severity Severe). It scanned clean right after download, then Defender quarantined it about a minute later.
This looks like a false positive. The !ml suffix means it is a Defender machine learning / cloud detection, not a signature match. That is the usual behavior for a brand new, unsigned NSIS installer with no cloud reputation yet.
VirusTotal backs that up: only 2 of 68 engines flag it, and both are heuristic / ML:
NANO-Antivirus: Exploit.Zip.Heuristic-java.csrvpr
Trapmine: Malicious.moderate.ml.score
Full VirusTotal report:
https://www.virustotal.com/gui/file/a7d ... 98d0927b77
The file is the genuine official installer. I downloaded it from the makemkv.com download link and the hashes match the copy on VirusTotal exactly:
File: Setup_MakeMKV_v1.18.4.exe
SHA-256: a7da42f08765f1186154eb3e2af08c30f0ac66b0a42aa7e4430aa498d0927b77
SHA-1: 348fc51c33ef81389a7ed6075cdacee0e9933350
MD5: a3da290dd2e0508579acd47c21964cbd
Posting in case it helps others, and in case it is worth submitting to Microsoft so the detection gets cleared. Anyone else seeing this on 1.18.4?
Sayaka
Re: 1.18.4 installer flagged by Windows Defender as Bearfoos.B!ml (likely ML false positive)
Post by Sayaka »
Likely a false positive. I did an antivirus scan for the Windows, MacOS, and Linux versions of MakeMKV 1.18.4 and it said everything's fine.
