Hello! i updated the soft to the last beta version (can't find a stable one) but when i enter my key activation, that i got from easeFab, it say "invalid key"!
The mail how give me a key date on 10/30/2018.
I try to reverse to v.1.8.1 but the key doesn't work to...
Can you help me please?
Cheers.
Gwen.
Invalid registration key
tomty89
Re: Invalid registration key
What's "easyfab" and what does it have to do with MakeMKV? Use the beta key here if you haven't purchased before: viewtopic.php?f=5&t=1053
youlk1234
Hello! First of all, easeFab is a rival to MakeMKV so understandably it won't accept their key. However (it could be a me problem), the key you (@tommy89) pointed to doesn't work anymore...
tomty89
As the post mentioned, it is updated on regular basis and the key currently in the post works until the end of July. I have no problem using it just now.
