What firmware do I need to flash on the BH16NS58?
Routine_Produce
Post by Routine_Produce » Sun Jun 14, 2026 7:04 am
I have heard the BH16NS58 is the same as the WH16NS60.
I see a few firmware files in the mk firmware pack that could work with my drive. Do I flash "HL-DT-ST-BD-RE_BH16NS50-1.03-NM00400-212004210958.bin" firmware or do I need the "HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin" or the "HL-DT-ST-BD-RE_WH16NS60-1.03-NM00600-212005081010.bin" firmware that is intended for the WH16NS60?
I have read some posts where people say WH16NS60-1.03-MK causes sleep issues and to use WH16NS60-1.02-MK and others that say 1.03 is fine. I am just trying to find accurate information. I would appreciate some help
Re: What firmware do I need to flash on the BH16NS58?
Post by MartyMcNuts » Sun Jun 14, 2026 7:52 am
Routine_Produce wrote: Sun Jun 14, 2026 7:04 am I have heard the BH16NS58 is the same as the WH16NS60.
The recommended firmware is WH16NS60 1.02-MK.
Routine_Produce
Post by Routine_Produce » Mon Jun 15, 2026 6:07 am
Flashed that firmware and it worked. Thanks
