Black bars left, right, top, bottom, but correct AR
dhstraayer
Post by dhstraayer » Sun Jun 14, 2026 12:19 am
Shows same on Roku Ultra and VLC. Aspect ratio is fine, but wasting a lot of screen.
makemkv problem.png (682.12 KiB) Viewed 5018 times
Re: Black bars left, right, top, bottom, but correct AR
Post by Woodstock » Sun Jun 14, 2026 2:21 am
Running the file through a program like handbrake will strip the black bars, making the file smaller.
tomty89
Post by tomty89 » Sun Jun 14, 2026 11:38 am
That's perfectly normal / expected when you play letterbox material on a non-4:3 screen though. You could "zoom in" / crop to get rid of the bars at the top and the bottom, but I suspect that the DVD subtitle would then not be shown properly.
