Any chance I would be able to get this firmware? I have the same drive (BDR-UD03) with Revision: 1.03.
Thank you in advance!
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
sure email me that info andnaugyhyde wrote: Sat Jun 06, 2026 8:11 am Any chance I would be able to get this firmware? I have the same drive (BDR-UD03) with Revision: 1.03.
all others email me no need to post your info here publicly just reach out to me directly
see below for email
I would like to upgrade my firmware, possible. Here is the info for my drive. Thank you for help!
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.11
Serial number: TFDL319901WL
Firmware date: 2018-11-28
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.11
Disc Information
Label: MAGNUM_PI
Timestamp: 2004-07-09 02:48:18
Protection: CSS/CPPM
Data capacity: 4.31 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 1 (PTP)
sure email me that info andRev. Zen wrote: Fri Jun 12, 2026 3:16 pm Hi,
Revision: 1.11
Disc Information
Label: MAGNUM_PI
Disc type: DVD-ROM
Disc size: 120mm
see below for email
georgesgiralt
Hello Guys,
An acquaintance will grab around 10 of these Pioneer drives. I will have the opportunity getting one for "free". Condition unknown.
From the various MakeMkv reports posted here, it looks like these drives are LibreDrive enabled with the original firmware.
Could one of you tell me what are the main features of these drives ? And what will be gained by flashing them ?
Many thanks in advance for sharing your knowledge !
P.S. : I plan to install it into an old Lenovo laptop. It will replace the DVD burner installed by Lenovo....
While many Pioneer drives / firmware are supported as LibreDrive, not all of them support UHD. "Modern" models (i.e. those have full BDXL support) can often be crossflashed with firmware from "sibling" models to gain the UHD support. There are also a few firmware that are not supported / recognized as LibreDrive, in which case you may want to crossflash it to make it a LibreDrive as well, or else you'll have to wait until mike add the support (which may or may not happen).
feixlweixl
Hello!Coopervid wrote: Tue Jun 02, 2026 8:07 pmYou are welcome. Enjoy!
I also have such a drive.
Was wondering if you could help me out too.
Thanks in advance,
Felix
Post your MakeMKV drive info. There're also BDR-UD03 drives out there with another platform which are not flashable (no BD writing, only BD reading and CD/DVD writing = combo drives).feixlweixl wrote: Thu Jun 18, 2026 7:31 pmHello!
Thanks in advance,
Felix
sure just email me the drive infofeixlweixl wrote: Thu Jun 18, 2026 7:31 pmHello!
Thanks in advance,
Felix
see below for email
Hmm first time I heard of this, although I'm aware of ASUS SBC-06D2X-U, which makes it less surprising I guess. Do you know if they come in specfic model suffix? (Like ones different from ASW or FAL?) And what is/are the platform (RS) number(s)?zittrig wrote: Fri Jun 19, 2026 5:29 am There're also BDR-UD03 drives out there with another platform which are not flashable (no BD writing, only BD reading and CD/DVD writing = combo drives).
Post your Makemkv info.feixlweixl wrote: Thu Jun 18, 2026 7:31 pmHello!
Thanks in advance,
Felix
BD combos with RS8591 can't be flashed. Only BD writers with RS8511.
By speaking of RS8950 ......
My brother got a ASUS SBC with this drive inside. It had firmware 1.03 with enabled LibreDrive.
He's a little bit an update freak and flashed to the last firmware 1.10. Now LibreDrive is disabled and Blu-ray ripping is possible only up to 2.1x.
In the web I can't find the 1.03. Anyone have this firmware tool from ASUS?
