sushi714
Re: SDFtool Flasher
Post by sushi714 » Fri Jun 12, 2026 4:21 pm
75th Trombone wrote: Thu Jun 11, 2026 9:23 pm Disregard the above. The device I received (from a Newegg seller) is counterfeit.
Glad I came across this post -- I have a feeling I ordered from the same 3rd party seller that shipped out of China (RIGX). Thought I was going crazy encountering the error with SDFtool and tried flashing via Powershell and even via Mac terminal since MakeMKV kept showing LibreDrive status enabled, but I encountered the same issue trying to use SDFtool and, regardless of how many times or what firmware I flashed, all the info in MakeMKV looked the same after each attempt.
Luckily I snagged the same model drive from Best Buy that's arriving soon -- showed as being a sold/shipped by them and not a 3rd party seller, so fingers crossed that one works, since I bought a few used UHD titles that apparently are 100GB UHDs that my Series X isn't able to read and just need to confirm they're actually UHDs and not counterfit lol
75th Trombone
Re: SDFtool Flasher
Post by 75th Trombone » Fri Jun 12, 2026 7:22 pm
The current theory on the VGPC Discord is that the fake drive I got is the correct internal drive in a fake/incompatible enclosure. (Because MakeMKV does say it is the correct platform.) They suggested I try a cheapo enclosure from Aliexpress that they say has a good success rate when a valid drive is put inside it. We’ll see!
Re: SDFtool Flasher
Post by Billycar11 » Fri Jun 12, 2026 7:47 pm
75th Trombone wrote: Fri Jun 12, 2026 7:22 pm The current theory on the VGPC Discord is that the fake drive I got is the correct internal drive in a fake/incompatible enclosure. (Because MakeMKV does say it is the correct platform.) They suggested I try a cheapo enclosure from Aliexpress that they say has a good success rate when a valid drive is put inside it. We’ll see!
whats your drive info look like? in makemkv
75th Trombone
Re: SDFtool Flasher
Post by 75th Trombone » Sat Jun 13, 2026 3:47 am
Re: SDFtool Flasher
Post by Billycar11 » Sat Jun 13, 2026 3:52 am
75th Trombone wrote: Sat Jun 13, 2026 3:47 am Image
do you have original drive info?
you partially flashed it.
does it still see discs?
have your tried cli flashing from the guide below?
