Help with DBZ Broly blu-ray image file
JoshiiBoi21
Let me start this off by saying, I don't have a blu-ray drive. I only have a modded PS3. Every time I try to use the ISO from Multiman, MakeMKV keeps getting stuck on processing titles and says /BDMV/STREAM/00031.m2ts corrupt or invalid at offset (offset, typically 12288 I believe) attempting workaround. it never does it. Please help. I don't know what to do.
Re: Help with DBZ Broly blu-ray image file
So far, we have little to work from. It sounds like whatever you used to make the image file skipped errors it found and just wrote what it could. That left you with errors that will prevent MakeMKV from properly parsing the data.
You may want to clean the disk and retry making the copy that you are trying to read.
JoshiiBoi21
I cleaned the disc and am now ripping it again. it says it's gonna take a few hours.Woodstock wrote: Fri Jun 12, 2026 4:29 pm So far, we have little to work from. It sounds like whatever you used to make the image file skipped errors it found and just wrote what it could. That left you with errors that will prevent MakeMKV from properly parsing the data.
JoshiiBoi21
it still does it, and It crashes when I try running it with debug logs on.JoshiiBoi21 wrote: Fri Jun 12, 2026 5:40 pmI cleaned the disc and am now ripping it again. it says it's gonna take a few hours.Woodstock wrote: Fri Jun 12, 2026 4:29 pm So far, we have little to work from. It sounds like whatever you used to make the image file skipped errors it found and just wrote what it could. That left you with errors that will prevent MakeMKV from properly parsing the data.
JoshiiBoi21
nvm I used the stinky DVDFab thing and it worked. this is NOT telling you guys to use it, just sharing MY solution :3
