Help with DBZ Broly blu-ray image file
JoshiiBoi21
#1 Post by JoshiiBoi21 » Fri Jun 12, 2026 2:46 pm
Let me start this off by saying, I don't have a blu-ray drive. I only have a modded PS3. Every time I try to use the ISO from Multiman, MakeMKV keeps getting stuck on processing titles and says /BDMV/STREAM/00031.m2ts corrupt or invalid at offset (offset, typically 12288 I believe) attempting workaround. it never does it. Please help. I don't know what to do.
Re: Help with DBZ Broly blu-ray image file
#2 Post by Woodstock » Fri Jun 12, 2026 4:29 pm
So far, we have little to work from. It sounds like whatever you used to make the image file skipped errors it found and just wrote what it could. That left you with errors that will prevent MakeMKV from properly parsing the data.
You may want to clean the disk and retry making the copy that you are trying to read.
JoshiiBoi21
#3 Post by JoshiiBoi21 » Fri Jun 12, 2026 5:40 pm
Woodstock wrote: Fri Jun 12, 2026 4:29 pm So far, we have little to work from. It sounds like whatever you used to make the image file skipped errors it found and just wrote what it could. That left you with errors that will prevent MakeMKV from properly parsing the data.
I cleaned the disc and am now ripping it again. it says it's gonna take a few hours.
JoshiiBoi21
#4 Post by JoshiiBoi21 » Sat Jun 13, 2026 2:04 pm
JoshiiBoi21 wrote: Fri Jun 12, 2026 5:40 pm
it still does it, and It crashes when I try running it with debug logs on.
JoshiiBoi21
#5 Post by JoshiiBoi21 » Mon Jun 22, 2026 4:11 pm
nvm I used the stinky DVDFab thing and it worked. this is NOT telling you guys to use it, just sharing MY solution :3
