Verbatim 43888 (LG BU40N) to Omnidrive
Pedalritter
Post by Pedalritter »
I want to flash a Verbatim 43888 (LG BU40N) with firmware version 1.05 (encrypted) to the OmniDrive firmware.
If I’ve read this forum correctly, I first need to flash the drive with the firmware “DE_LG_BU40N_1.03_MK.bin” from the “From the All You Need Firmware Pack (MartyMcNuts)”, and then flash it with OmniDrive.
Flashing is done exclusively with the SDFtool Flasher.
Is all of this correct?
Thank you and best regards.
Translated with DeepL.com (free version)
OneDay
Re: Verbatim 43888 (LG BU40N) to Omnidrive
Post by OneDay »
Krawk wrote: Tue Jun 02, 2026 6:46 pm Info about Omnidrive here...
https://www.timeextension.com/news/2026 ... -ray-drive
Then go here for the Omnidrive
Mr. Red wrote: Tue Jun 09, 2026 11:58 am https://github.com/ribshark/omnidrive
katana!
Post by katana! »
That’s exactly how I understand it as well. You need to switch to the "DE_LG_BU40N_1.03_MK.bin" firmware to replace the encrypted V1.05 firmware. After that, you can flash the OmniDrive firmware directly.
Let me know once everything has worked.
Pedalritter
It works, thanks @ all ;-)
katana!
Post by katana! »
Perfect! I was a bit confused at first too, but this post helped me.
MartyMcNuts wrote: Tue Feb 24, 2026 10:34 pm
Fastnbulbous1969 wrote: Tue Feb 24, 2026 9:59 pm Okay, again:
"If your external Buffalo / Archgon / LG BU40N has encrypted firmware, flash BU40N 1.03-MK first, then you can either leave it as is or flash BU40N 1.00 or Buffalo BU / BN firmware if you want to."
I don't see the BU40N 1.03-MK in the all you need firmware pack, only the stock firmware: HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
These are one and the same. If it has "NM" in it then it is the MK firmware and it is easier to say MK than NM00000-21.....
