Hi
I have an already flashed cfw UHD blue ray drive,model is PIOONER BDR-213-EBK,which external enclosure should I pick that supports it for rippin and reading?
can pick only models avaible in the eu.
Thanks everyone
[PIOONER BDR-213-EBK] Lookin for an external enclosure that supports flashed UHD drive
BuddRenard
Re: [PIOONER BDR-213-EBK] Lookin for an external enclosure that supports flashed UHD drive
Get the owc mercury pro
Do not get the vantec no matter what anyone tells you they kill drives
BuddRenard
Seems a pretty solid choice,better than what you could get off amazon fur sure it seems,thanks for the suggestions,so it will work fine with my cfw drive? no problems or reset of the flashing?Billycar11 wrote: Mon Jun 08, 2026 2:39 pm Get the owc mercury pro
thats my biggest fear lol
Yes owc fully works with pioneers for flashing and libredrive use.BuddRenard wrote: Mon Jun 08, 2026 4:37 pmSeems a pretty solid choice,better than what you could get off amazon fur sure it seems,thanks for the suggestions,so it will work fine with my cfw drive? no problems or reset of the flashing?Billycar11 wrote: Mon Jun 08, 2026 2:39 pm Get the owc mercury pro
With the owc mercury pro the pioneer drives do not fit all the way in unless you do a mod that you will need to bind the mounting tabs inside the case.
If a case is not a priority then get this Benefei Sata to USB 3.0
https://a.co/d/0eXsnT4O
I can also highly recommend the Benfei adapter.OneDay wrote: Fri Jun 12, 2026 1:32 am If a case is not a priority then get this Benefei Sata to USB 3.0
