Successful install on Arch (EndeavourOS)
sun_lmao
Post by sun_lmao »
I just got MakeMKV installed and working on EndeavourOS (which is basically just Arch but easy to install).
I looked it up and found the equivalents to the dependencies listed for Debian/Ubuntu gives this:
sudo pacman -S base-devel gcc pkgconf glibc openssl expat ffmpeg mesa qt5-tools zlib
However, at least on Endeavour, (almost?) all of these seem to already be installed, so it wasn't strictly necessary.
Then the typical ./configure, make, sudo make install, make, sudo make install stuff...
I then had to run this command for MakeMKV to actually recognise my Blu-ray drive:
modprobe sg
From a quick Google search, a StackExchange thread suggested this to make that change permanent:
echo b43 | sudo tee -a /etc/modules
Not only did this work a treat, but VLC (from the Arch repository, as included by default in Endeavour) integrated with it instantly, without any hassle (which wasn't the case when I tried it with Ubuntu a while back, funnily enough).
I don't know if I did anything wrong here, but if not, I hope other Arch/Endeavour enjoyers find this useful. :)
(Also, thanks to the MakeMKV dev. This programme is awesome. I was a free user for many, many years and I just recently bought a license. It's worth the money.)
iainnitro
Re: Successful install on Arch (EndeavourOS)
Post by iainnitro »
Greetings: I also used MakeMKV for awhile and then decided to buy a license. I am also on EOS (EndeavourOS) and most everything I use is available either natively or of course in the AUR
I just wanted to offer thanks for this post as I just installed "Mercury" coming back to Linux from Windows 11. I have not tested MakeMKV with my drive yet, but I feel you may have saved me some troubleshooting time as I I am sure that I will need to do the mod probe and add the module dance when I do connect the drive.
TheShinx317
Post by TheShinx317 »
Thanks for the advice! I'm using Garuda Linux (Arch) in 206 and using
modprobe sg
still works all this time later.
