Enclosure / cable recommendation for BU40N I can buy from within the EU?
pustal
#1 Post by pustal » Tue Jun 09, 2026 9:53 pm
Hello everyone. I was trying to fine a USB enclosure (or cable if that fails) for my BU40N. I live in Portugal and all the reccomended cases I find, I only seem to find them for sale from US sellers on eBay and that would be a blow on import taxes.
Do you guys know and can recommend me something I can buy from here? Even if is from AliExpress and such (since they use European warehouses to sell from here).
Thank you.
georgesgiralt
Re: Enclosure / cable recommendation for BU40N I can buy from within the EU?
#2 Post by georgesgiralt » Wed Jun 10, 2026 4:13 am
I've a DELOCK 42595 which is perfect. This exact model is not made any more but they have a replacement. They are in Germany if I'm not mistaken.
katana!
#3 Post by katana! » Wed Jun 10, 2026 8:59 am
I also recently bought a BU40N drive. What firmware version and production date does yours have?
As you can see from my post, I own a Delock 42603 enclosure.
viewtopic.php?p=200863#p200863
It works with my ASRock DeskMini A300 (Windows 10) and my 2019 MacBook Pro. However, unlike its predecessor (the Delock 42595), it doesn't have an external 5V DC port.
I can't confirm whether it's suitable for firmware flashing (i want OmniDrive for Games preservation) or ripping 4K UHD discs, though, because—at least for the moment—LibreDrive support or the drive platform isn't showing up for me.
That’s why I ordered the following items:
  • BENFEI USB 3.0 to SATA adapter (2-in-1 USB-C/USB 3.0 to SATA III adapter for 2.5"/3.5" HDD/SSD and SATA optical drives; includes 12V/2A power adapter; supports UASP)
  • CY Adapter Slimline SATA 7+6 (13-pin) optical drive to SATA 7+15 (22-pin) adapter
You can order these from Amazon Germany.
georgesgiralt
#4 Post by georgesgiralt » Wed Jun 10, 2026 3:07 pm
Are you sure there is no power port ? I had an enclosure where the female plug was on the PCB but no holes were made in the box to let the male plug connect.... It was an easy fix.
Also recent SATA/USB interface chips are better than they were. (nowadays, one chip can do every variant of SATA interface, be it OD or DD or SSD... ) So if you enclosure is not that old, it should be OK for firmware update...
katana!
#5 Post by katana! » Wed Jun 10, 2026 5:25 pm
It was the enclosure's fault! I can confirm 100% that the Delock 42603 enclosure does not provide an optimal SATA-to-USB connection. Furthermore, the PCB inside the enclosure lacks a port for a power adapter.
After connecting the BENFEI USB 3.0 to SATA adapter—along with its included 12V/2A power adapter and the CY Slimline SATA (7+6/13-pin) optical drive to SATA (7+15/22-pin) adapter—to my MacBook, MakeMKV now recognizes the drive platform "MT1959" and reports the LibreDrive status as "Possible, not yet enabled."
Tomorrow I’ll test it on the DeskMini A300 (Win 10) and see if SDFTool Flasher also now correctly detects the drive.
tomty89
#6 Post by tomty89 » Wed Jun 10, 2026 6:23 pm
I don't think that part matters though. Most likely neither the adapter nor the drive will / can draw power from the 12V and I doubt that it has any 12V to 5V conversion. The 12V should only matter when it's a 3.5" HDD / 5.25" ODD.
katana!
#7 Post by katana! » Wed Jun 10, 2026 7:20 pm
That is possible; I can test it tomorrow without the 12V connection. However, if that turns out to be the case, the problem lies with the SATA-to-USB chip inside the Delock 42603 enclosure. As previously mentioned, when using the Delock enclosure, neither MakeMKV nor the SDFtool Flasher detects the "MT1959" drive platform, nor is the drive recognized as "LibreDrive" or as having "encrypted firmware." These lines are missing or do not have a green checkmark.
I was able to test it on the DeskMini A300 as well. It works perfectly now, just like on the MacBook, and is correctly recognized.
@tomty89
Thanks for your comment! The Benfei adapter works perfectly without the 12V connection or the BU40N.
johannu
#8 Post by johannu » Sat Jun 13, 2026 7:35 am
I can recommend RaidSonic Icy Box IB-AC640-C3 (USB 3.2 Gen 1). I use it for my LG BU40N, works flawless...
See: https://raidsonic-static-content.s3.eu- ... 0-C3_e.pdf
Unfortunately, it's already very difficult to obtain. If you need one, PM me.
black_raven
#9 Post by black_raven » Fri Jul 03, 2026 6:19 pm
I have here some cheap USB2Sata box from Aliexpress based on Prolific Technology PL2773 USB 3.0 chipset.
Not sure I can rely on it with my Pioneer UHD drive.
Maybe some firmware update is needed, just started to look for firmware update tool.
If anyone has some information please share. :idea:
AM6B+ Coreelec, OPPO UDP-203, Asus PC BW-16D1HT
katana!
#10 Post by katana! » Tue Jul 07, 2026 2:07 pm
If anyone is still looking for a suitable case within the EU, I can recommend this one.
techPulse120 externes USB 3.0 Laufwerksgehäuse (Gehäuse ohne Laufwerk) Case Caddy für Slim 9,5 mm SATA Laufwerke
applejuice
#11 Post by applejuice » Wed Jul 15, 2026 7:28 am
I can also highly recommend the TechPulse 120 USB 3 case! It fits the BU40N perfectly — I was even able to keep the original bezel on it. In Germany, the LG BU40N is currently available for around 90 euros at Galaxus. I received a new drive, manufactured in March 2026, and flashing it to 1.03MK and then to 1.00 went smoothly with this enclosure.
PistolPete76
#12 Post by PistolPete76 » Sun Jul 26, 2026 6:13 pm
johannu wrote: Sat Jun 13, 2026 7:35 am I can recommend RaidSonic Icy Box IB-AC640-C3 (USB 3.2 Gen 1). I use it for my LG BU40N, works flawless...
Hi johannu,
Unfortunately as a new user I can not PM people yet.
I am chasing an Icy Box IB-AC640-C3 enclosure and reaching out to you to see if you can help as mentioned in this post.
Regards.
