These original flashers only work for that particular model, so no.Konten wrote: Tue Feb 17, 2026 4:09 pm Thanks so much for these, Marty!! It's really appreciated!!
Will the BP50NB40 1.03 firmware work for a BP55EB40 SVC: EB52 as well?
LG Original Firmware Flashers (to return to original firmware)
Re: LG Original Firmware Flashers (to return to original firmware)
hansolo
Just curious, probably won't ever need these original flashers. My BH16NS55 is crossflashed to WH16NS60. If I ever was to downgrade to original FW, which original flasher should I use. 55 or 60? I assume 55 or is workflow first crossflash back to 55 and then apply original 55 flasher?
LG BH16NS55 (crossflashed w/ WH16NS60 1.02MK) in external enclosure
LG BU40N (1.03MK) in external enclosure
LG BU40N (original 1.00)
Verbatim #43888 (Pioneer BDR-UD04 FW1.14)
Pioneer BDR-208D (crossflashed w/ BDR-S11JX/BDR-211)
zittrig
There's a LG universal flashing tool which recognize the right model or firmware by itself.
Well you didn't say which original firmware. If you want to go back to original NS55 firmware, you would first have to flash a NS55 MK version that is lower than the original NS55 flasher firmware version, then use the NS55 original flasher.hansolo wrote: Wed Feb 18, 2026 6:48 am Just curious, probably won't ever need these original flashers. My BH16NS55 is crossflashed to WH16NS60. If I ever was to downgrade to original FW, which original flasher should I use. 55 or 60? I assume 55 or is workflow first crossflash back to 55 and then apply original 55 flasher?
hansolo
Yes thanks. I meant back to original NS55, which the drive label states it is
Would this tool know what is the truly original if the drive was crossflashed.zittrig wrote: Wed Feb 18, 2026 7:25 am There's a LG universal flashing tool which recognize the right model or firmware by itself.
zittrig
I can't say it just now. Check it out, it will talk to you before you can start the flashing process.
It could be that it recognize the WH16NS60-Firmware and will take this as base for the flashing.
If you're unsure with useing the tool I can test it later after work with a BH16NS55 @ WH16NS60 1.02MK and report back here.
Or Marty can say it here right now with a lot more of expierience.
No, it would go by what the firmware is on the drive. If NS60 firmware, it would think the drive is a NS60.hansolo wrote: Wed Feb 18, 2026 9:48 am Yes thanks. I meant back to original NS55, which the drive label states it is.
Konten
Thanks, Marty!! If you ever happen to come into possession of the original BP55 firmware, please do post it…MartyMcNuts wrote: Tue Feb 17, 2026 9:47 pmThese original flashers only work for that particular model, so no.Konten wrote: Tue Feb 17, 2026 4:09 pm Thanks so much for these, Marty!! It's really appreciated!!
Hi everyone,
If anyone is looking for the original BU40N 1.05 firmware, here is the official LG Updater exe.
https://www.mediafire.com/file_premium/ ... r.zip/file
Only use this to restore your BU40N back to the original 1.05 firmware. This firmware is not UHD enabled!
OneDay
Hi
Just was wondering if anyone had the original WH16NS60 firmware 1.01? Thanks
Sayaka
Late to the party but :
This is what you're looking for :
https://gscs-b2c.lge.com/downloadFile?f ... 5vTRuHnCew
and this :
https://gscs-b2c.lge.com/downloadFile?f ... G0VxDHHRng
is the official LG firmware update guide.
and this :
fiatou
Does anybody have the original BU40N 1.05 firmware suitable for a Verbatim 43888-BU40N drive ?MartyMcNuts wrote: Sun Feb 22, 2026 10:13 pm If anyone is looking for the original BU40N 1.05 firmware, here is the official LG Updater exe.
This one hangs at 48% and the drive is semi-bricked (stuck as boot). It can be reflashed first using DELL flasher as described in another topic.
The Verbatim 43888 contains a LG BU40N. This LG flasher is the correct flasher to restore it back to v1.05. I have not heard from anyone else having any issues using it. I heard the dell one is indentical, just v1.03 instead. Not sure why it isn't working for you.fiatou wrote: Tue Jun 09, 2026 6:21 pmDoes anybody have the original BU40N 1.05 firmware suitable for a Verbatim 43888-BU40N drive ?MartyMcNuts wrote: Sun Feb 22, 2026 10:13 pm If anyone is looking for the original BU40N 1.05 firmware, here is the official LG Updater exe.
fiatou
I could read it there : viewtopic.php?p=196092#p196092MartyMcNuts wrote: Wed Jun 10, 2026 1:04 am I have not heard from anyone else having any issues using it.
It was exactly same story, stuck at 48%
Looks like the LG 1.05 can't be applied on all Verbatim 43888-BU40N, for a reason I don't know.
fiatou
Well... it looks like my verbatim enclosure and/or USB cable (which was shipped with) doesn't handle USB3 very well/are defective - although new.
I tried and failed on 2 different laptops before.
I use a cheap cable, it was connected using USB2, and everything went fine.
