[PIOONER BDR-213-EBK] Lookin for an external enclosure that supports flashed UHD drive
BuddRenard
#1 Post by BuddRenard » Mon Jun 08, 2026 11:51 am
Hi
I have an already flashed cfw UHD blue ray drive,model is PIOONER BDR-213-EBK,which external enclosure should I pick that supports it for rippin and reading?
can pick only models avaible in the eu.
Thanks everyone
Re: [PIOONER BDR-213-EBK] Lookin for an external enclosure that supports flashed UHD drive
#2 Post by Billycar11 » Mon Jun 08, 2026 2:39 pm
Get the owc mercury pro
Do not get the vantec no matter what anyone tells you they kill drives
BuddRenard
#3 Post by BuddRenard » Mon Jun 08, 2026 4:37 pm
Billycar11 wrote: Mon Jun 08, 2026 2:39 pm Get the owc mercury pro
Seems a pretty solid choice,better than what you could get off amazon fur sure it seems,thanks for the suggestions,so it will work fine with my cfw drive? no problems or reset of the flashing?
thats my biggest fear lol
#4 Post by Billycar11 » Tue Jun 09, 2026 8:26 am
BuddRenard wrote: Mon Jun 08, 2026 4:37 pm
Yes owc fully works with pioneers for flashing and libredrive use.
OneDay
#5 Post by OneDay » Fri Jun 12, 2026 1:32 am
With the owc mercury pro the pioneer drives do not fit all the way in unless you do a mod that you will need to bind the mounting tabs inside the case.
If a case is not a priority then get this Benefei Sata to USB 3.0
https://a.co/d/0eXsnT4O
katana!
#6 Post by katana! » Fri Jun 12, 2026 1:57 pm
OneDay wrote: Fri Jun 12, 2026 1:32 am If a case is not a priority then get this Benefei Sata to USB 3.0
I can also highly recommend the Benfei adapter.
